audi rs2 smoking on idle
  • Rikki Kitto
    • Feb 2010
    • 6276
    I've used castrol Edge 10/40 for years with no smoking (well the odd cloud when not used for a while and booting it too early) reckon I'm getting close to 200,000 miles too
    • gmac78
      • Oct 2009
      • 928
      • Home: Scotland
      #32
      Looks like i've been using too thin an oil then, i'm intrigued to see what difference the thicker oil makes. Before i bought the standard RS2 turbo i had purchased a Hoffer RS2 hybrid which did the same thing with smoking at idle but this was tried with the same type of engine oil. Perhaps the thicker oil would have cured that turbo. Infact i don't think i'll be needing that turbo now as the TS chips i have are for a standard RS2 turbo, the fuelling would no doubt be out with the Hoffer special, i only ever had it running at idle before the car was fit for the road. Might stick this up for sale soon actually to see if theres any interest.
      Time to research thicker oil to see where the cheapest place to buy is.
      As always guys, thanks for the help.
      • vag_noob
        • Nov 2010
        • 72
        • Country: New Zealand
        #33
        don't think you need thicker oil under normal temperatures, running 10w/40 full synthetic at 280km
        • Gazmitchell
          • Feb 2013
          • 640
          Originally posted by SteveH
          I run Fuchs Titan 10/50 and have no smoking. Tried a similar Millers synthetic a few oil changes ago and got smoking on idle. Changed back to the Titan and no smoking. It does appear that the type and viscosity of your oil can cause these issues. 5/30 is way below the manufacturer's spec for these motors. I'd go with a 10/40 or 10/50.
          I've rebuilt my ABY engine up to rs2 spec with new compressor turbine and shaft and balanced , also 360deg bearing in the stock Rs2 turbo, yet to fire the engine up but I've put new quantum 5/40 in it ? Think this is ok ? Or should I run it then change to a 10/40 ?
          • SteveH
            • 4460
            I recon you will be fine using that. I've been told it's best to stick with one oil type/brand if possible, as changes to the oil type can be detrimental to old seals. Not sure whether this is true, but it sounds plausible.
            91 Modded 3B
            14 A6 Avant Black Edition
            • mike74
              • Apr 2014
              • 615
              this is the stuff you want (probably won't find cheaper either!)
              http://www.ebay.co.uk/itm/Millers-Oi...4AAOSwjDZYhuFY
              I use millers stuff in all my motors and swear by it. Oil consumption usually goes down over the first couple of months and the engines definitely sound quieter too. Good oil at reasonable price IMO
              • Rikki Kitto
                • Feb 2010
                • 6276
                With my Halfrauds discount card I get 4L Castrol Edge for £30
                • gmac78
                  • Oct 2009
                  • 928
                  • Home: Scotland
                  #38
                  Just ordered of 8l Castrol Edge 10w 40 and filter, delivered for £56, see if this oil improves the smokey RS2 turbo?
                  • Gazmitchell
                    • Feb 2013
                    • 640
                    Yeh keep us updated on the results 👍..
                    Think this has been covered in detail times past with the oilman , but different spec cars , how they're driven and their use require diff oils I guess , but the quantum platinum is what Audi / VAG specced me 5/40 so won't know if it'll smoke until I run it as I've not had this turbo on it in the past so can't compare..
                    • bivw
                      • Mar 2011
                      • 72
                      Dont think its help but give it a try
