So, i posted a while ago about my new S2 Avant.. Test drove it tonight, and oil preassure is fine
it also has an oil leak... Funny thing is, the oil it's leaking is very yellow, a bit like hydraulic fluid but brighter. The PAS resevoir has the usual green stuff in it, and the engine oil is more black than gold (havent got round to changing it yet) this yellow stuff is also very "dry" or harsh if i rub it between my finger and thumb, not smooth like fresh motor oil. Could it be from the non functional AC? AC compressor is dry, and the leak comes from the front end... Back side of alternator is a bit wet, and AC pipes are wet but could be just leeking on them and running along till it hits the lowest point and ends up all over the oilpan. Also, i saw that the brake bomb seems quite moist/wet but seems to work. What baffles me is this yellow substance... Any ideas?
Cheers,
Kris
it also has an oil leak... Funny thing is, the oil it's leaking is very yellow, a bit like hydraulic fluid but brighter. The PAS resevoir has the usual green stuff in it, and the engine oil is more black than gold (havent got round to changing it yet) this yellow stuff is also very "dry" or harsh if i rub it between my finger and thumb, not smooth like fresh motor oil. Could it be from the non functional AC? AC compressor is dry, and the leak comes from the front end... Back side of alternator is a bit wet, and AC pipes are wet but could be just leeking on them and running along till it hits the lowest point and ends up all over the oilpan. Also, i saw that the brake bomb seems quite moist/wet but seems to work. What baffles me is this yellow substance... Any ideas?Cheers,
Kris
