Hi all,
I have searched and cannot find a similar thread, forgive me if I've missed one.
First off, this is an ABY engine with the type A ecu (no immob) and it's built into a kit car. The AC and P/S pumps are removed, the original wiring loom is in use but has been shortened (by me) and the ECU is chipped, not by me.
I have added a black box with an LED and switch connected to the engine light output from the ECU so I can simply check for errors using flashing lights.
With engine running I have run the ecu test using the led, and the system returns 4444, all okay.....but last week and a few other times the engine cuts out and won't start. This could be while idling or driving. What is apparent is when I turn on the ignition, before it start the engine when the ecu is playing up the LED flickers or doesn't light up at all. When things are working fine the LED comes on and shines a solid colour as it should.
After this long preamble, the question I have is, what could cause this issue? The normal ground and 12v and lose connections on the ECU I have tried, but are there any external components (knock sensor etc) that could cause this issue?
I used this site for most of my information: http://www.sjmautotechnik.com/troubl...ng/ecu20v.html
