what limits hp when remapping?
  • prj
    • Mar 2010
    • 6308
    Originally posted by quattrostyle
    Dmitri could/can supply the MAP sensor as well. Actually I would just send your ECU to him and let him do the job.
    Price wise incl. return shipping, incl. MAP sensor etc is usually 200 EUR on these.
    • Ross
      • Aug 2005
      • 3399
      The extra 50-60hp of a remap will make a big difference. With exhaust and intake improvements mine was knocking on 300hp, albeit with a custom map.
      In short, do no underestimate the improvement of +25% horsepower!
      • hunker7
        • Mar 2014
        • 3487
        That is well cheap Will be letting you know when I decide to put more horses in my S4
        Thanks mate. As I said, atm not planning on having a remap, first want to sort the car out so it runs nicely on stock setup, then exhaust and FMIC....and then will get a remap
        I had a look at parts needed to go Stage 2/3, most expensive parts are turbo and manifold, everything else isn't that bad.
        '93 Audi UrS4 Avant
        '15 Audi A7 quattro 3.0 TDI
        • elaw
          • Jun 2012
          • 62
          Keep in mind that once you reach a certain power level, "engine parts" may not be all you need!
          I've got no internal engine mods (AAN), but a K24-7400 turbo, Megasquirt, and a few other goodies. Once cold day recently when I hit about 22 PSI of boost, my (stock 3B) clutch started slipping...
          Be alert! America needs more lerts.
          Eric Law
          '90 80Q with AAN and Megasquirt
          '97 Saab 9000 Aero: mostly stock but ECU tweaks to add fastness
          '86 4KTQ: R.I.P.
          • hunker7
            • Mar 2014
            • 3487
            #20
            I understand, I am not going to Stage 2, 3 and beyond. 300HP would be plenty enough, more than enough for my needs, been driving 150HP A100 and that was quick enough Nice remap from prj + exhaust system and I'll be sorted.
            '93 Audi UrS4 Avant
              Originally posted by hunker7
              Thanks mate. As I said, atm not planning on having a remap, first want to sort the car out so it runs nicely on stock setup, then exhaust and FMIC....and then will get a remap.
              You keep talking "remap". Remap to me means live custom tuning, which is often necessary when going with a non-standard combo of turbo, injectors and exhaust manifold. From what you are currently planning, that is not necessary.
              In your case, with the stock K24-7000 turbo and injectors, *ALL* you need is a Stage 1+ chip set with 3 Bar MAP sensor installed. Dmitri's offer to do everything for 200 Euros is a fantastic deal. Go for it.
              As for FMIC, you won't need it. Waste of time and money until you jump up to RS2 levels, i.e. K24-7200 turbo or equivalent with RS2 exhaust manifold (or better) and larger injectors. If you stay with Audi parts to do that, you don't shouldn't need a custom map for that either. There are lots of off the shelf chip sets for that hardware combo.
              You will not get above 280 hp without a larger turbo and injectors so don't dream about 300 hp because you add an exhaust system to Stage 1+. The stock UrS exhaust is not restrictive until you approach 400 hp.
              • hunker7
                • Mar 2014
                • 3487
                #22
                Getting my terminology wrong.. I meant chip I know FMIC won't make any difference in power, but only reason I am looking at installing one is because I want bumper mounted fog lights, so if I mount those, OE SMIC won't get enough air
                And exhaust, I need one anyways, as mine is all rusty and it's been patched already.
                '93 Audi UrS4 Avant
                  Hmm... you get so much fog that the OE UrS4 three-way (high, low/dipped, fog) headlights don't work for you? Those are going to be very expensive fogs if you are going to install a FMIC just to be able to run C4 100 fogs in the bumper corners. BTW, how are you going to handle the oil cooler which is behind the right corner bumper opening if you put a fog light there?
                  • hunker7
                    • Mar 2014
                    • 3487
                    #24
                    It just looks better imho. Could relocate that too
                    '93 Audi UrS4 Avant
                    • Majorcina
                      • Jun 2013
                      • 1334
                      • Country: Montenegro
                      #25
                      I wouldnt bother with that mate
                      • quattrostyle
                        • Oct 2006
                        • 6229
                        I agree it looks better
                        • hunker7
                          • Mar 2014
                          • 3487
                          #27
                          Looks angrier
                          '93 Audi UrS4 Avant
                          • Majorcina
                            • Jun 2013
                            • 1334
                            #28
                            I dont like it honestly Its bether OEM looking.I think non s4 had that style fog lights?Only in the headlights
