hi Guys
i swapping my rs2 turbo for a gt3076r with a/r 0.82 (goal 500hp)
what is the max boostpressure and redline for this turbo?
maybe 2.2bar peak and 1.9 bar redline?
my setup is rebuild AAN with arlows rods and wossner pistons(good for 800hp) cr 8:1so high boost possible
and also higher timing maybe?
the rest is stock head and AAN cams,tubular ex manifold,bosch 044 pump and siemens deka 630cc
i want to know how high i can fill in my boost&rpm curve from vems so if it's 2.2 bar peak on 4000 rpm then it is 320kpa correct?
has anyone with about the same setup a vems config for me ?
the ve table i program with "VE ANALYSER" on the road
thanks
nick
and also higher timing maybe?the rest is stock head and AAN cams,tubular ex manifold,bosch 044 pump and siemens deka 630cc
thanks
nick
