b2 coupe quattro 500hp project in progress
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    #46
    today i had some bad luck,while i was tuning on the road I suddenly saw a white cloud under my hood coming out.
    Water gushed out my water reservoir(overpressure) and fan was running at full speed!
    the engine temp and oil temp was 100°c so that was good
    my dad has pulled me back home with his car
    afterwords I put back some water on the engine and everything seems to be normal
    i think my radiator and fan or to small for my engine upgrade so i will wait for tuning until my new 70mm radiator is in place with rs2 500w fan
    I hope that my head gasket is not broke
    also i going to place a new reservoir with new plug
    TWINCHARGED power,zero lag
    AEM W/M injection
    • quattrostyle
      • Oct 2006
      • 6229
      Headgasket should be fine I think. I take it you have the metal gasket?
      • quattro-nick
        • Sep 2012
        • 1746
        • Country: Belgium
        #48
        yes,i have a metal gasket and arp head studs
        AEM W/M injection
        • andy10v
          • 5996
          Radiator could be partially blocked?
          Sold ABY-stock
          • quattro-nick
            • Sep 2012
            • 1746
            • Country: Belgium
            #50
            could be,it's still the origional one (48mm) but first I'm going to place my alu rs2 70mm radiator with bigger fan until I go back on the road
            AEM W/M injection
            • snaak
              • 153
              We had the same issue on my rs2 when tuning on vems. After that everything was fine again. Are you running water or coolant? I suspect it was a sticking thermostat on my car.
              '95 RS2
              • quattro-nick
                • Sep 2012
                • 1746
                • Country: Belgium
                #52
                water with antifreeze on the engine
                will it make much difference with coolant?maybe 5-10 degrees?
                i will put also a new thermostat to be sure but
                AEM W/M injection
                • quattro-nick
                  • Sep 2012
                  • 1746
                  • Country: Belgium
                  #53
                  Time for an update and pictures after a long time
                  so,i ordered a rs2 70mm radiator by vidar here on the forum ,great stuff !
                  i placed a new thermostat and coolant reservoir and put some new wires for a rs2 500watt fan with blue resistorplate
                  for the radiator I have adapt a few things like coolant manifold on the head and the left inner chassis leg
                  AEM W/M injection
                  • quattro-nick
                    • Sep 2012
                    • 1746
                    • Country: Belgium
                    #54
                    rebiuld coolant manifold
                    i make the connection tube more backwards
                    AEM W/M injection
                    • quattro-nick
                      • Sep 2012
                      • 1746
                      • Country: Belgium
                      #55
                      some wires and blue risistorplate for the fan
                      AEM W/M injection
                      • quattro-nick
                        • Sep 2012
                        • 1746
                        • Country: Belgium
                        #56
                        rebiuld chassis leg on the left
                        AEM W/M injection
                        • quattro-nick
                          • Sep 2012
                          • 1746
                          • Country: Belgium
                          #57
                          the radiator with fan
                          you can see the difference between the 2,on the left the new rs2 70mmradiator
                          also i have adapt the fan a little bit to make room for the washer reservoir
                          AEM W/M injection
                          • quattro-nick
                            • Sep 2012
                            • 1746
                            • Country: Belgium
                            #58
                            some airguides
                            AEM W/M injection
                            • quattro-nick
                              • Sep 2012
                              • 1746
                              • Country: Belgium
                              #59
                              final enginebay
                              AEM W/M injection
                              • quattro-nick
                                • Sep 2012
                                • 1746
                                • Country: Belgium
                                #60
                                so i have make a few testdrives and programming vems a little bit and i'm happy with the results
                                i drive today with 37°c outside and my coolant temp stays on max around 95°c and my oil temp stays max around 100 °c
                                so my final coolant: rs2 70mm alu radiator for watercoolant and 3 oilcoolers
                                3 oil coolers yes,1 origional oilcooler from AAN in series with a mercedes oil cooler in the front bumper and 1 water/oilcooler on the oilfilter house
                                i know,it's 2much but i want to play safe and oil pressure stays good,2bar on idle and 5 bar on 2500 rpm
                                AEM W/M injection
