Nope nothing on mine, perhaps yours is ABT specific?
b2 coupe quattro 500hp project in progress
No its just newbie ******** lol, I realised it was an extension of the big cooler ^^Comment
monday i'm going to work on the car again and check some things like are my coolantpipes open from turbo
i also place a heatcover over the exhaust manifold and change my oiltemp sender
maybe move my oil and coolantpipes from turbo a little bit
i also thought maybe place a heat exchanger on the oilfilterhouse from a vw,it's easy to place and put it in series with the coolant pipe from turbo
i think this help for my oiltemp
you will hear the results next week
TWINCHARGED power,zero lag
AEM W/M injectionComment
Today i have placed a turbopamper that I bought on ebay.de and made a heatcover for the exhaust manifold, it is attached around the manifold with springs
(the material was originally a large turbo pamper from a truck that I have adapted)
I also changed my water lines,the first piece on the turbo begins with a steel pipe for the heat around the turbo
I had a dump valve placed from 034 motorsport but was not satisfied with the flute noise that it made so I put back the origionele dumpvalve
i also placed a new oiltemp sender and temp sender behind the cylinder head
Wednesday i go back on the road
the last picture is taken under the manifoldaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
it's almost ready bart,tomorrow i go tune my vems
after a few weeks a update!
because my oiltemp was a bit high i placed a coolant oilcooler from a golf on the oilfilterhouse.
i made some custom tubes and a heatshield for the downpipe
i made one connection on the back from the engine and one on the upper radiator hoseLast edited by quattro-nick; 4 June 2014, 11:00.audi coupe quattro b2 2.2 20vt project (573hp-626nm)
also i drilled extra holes in my sump protection for better sumpcooling
i made a extra air-ventilation in the front bumper for a better cooling for the ic
now the only thing i must do is to swap the mat sensor with a 1.8t one from golf 4 20v
and reprogram vems a bit and afterwords i can go back on the road for adjustmens in vems and can i see how it is with the oiltemp againaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
Good initiative on the oil cooler, but did you not want to use a mocal item?
In the past on my mk2 golfs those coolers have a tendency to corrode internally and brake down, resulting in oil/ water mix. Giving the the impression that the head gasket has failed. I'd have bought a new one just to rule this out.
Good luck brining the temps down anyway. Hope it works for you.
Stuart
B2 90 quattro with boost
thanks
if everything is okay, I'm going to place a new cooler
future work:-Polyurethane rubbers in the suspension
-rollcageaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
after all the changes I've made over the past three weeks, I finally made a testdrive with the car and the results were present
oiltemp was max 110°c while i was tuning vems with ve-analyser !
i going to make more testdrives and if everything stays okay i make an appointment for the dyno
i can make more power with ignitiontable but that i leave for the tuner and play safe for now
i also ordered an rs2 70mm alu radiator by vidar skotheim and that will be my next job
what is his function indeed? wasn't it enough with the principal one ?
