b2 coupe quattro 500hp project in progress
  • Bowie69
    • Nov 2013
    • 2675
    Nope nothing on mine, perhaps yours is ABT specific?
    • Seb20V
      • May 2014
      • 81
      • Country: Belgium
      #32
      No its just newbie ******** lol, I realised it was an extension of the big cooler ^^
      Seb
      http://www.carthrottle.com/garage/CS...o-2-3-20v-abt/
      • Bowie69
        • Nov 2013
        • 2675
        Oh, the aux Radiator
        • Seb20V
          • May 2014
          • 81
          • Country: Belgium
          #34
          yes what is his function indeed? wasn't it enough with the principal one ?
          Seb
          • Bowie69
            • Nov 2013
            • 2675
            Not REALLY needed, but Audi seemed to think so, guess hotter climates maybe?
            • quattro-nick
              • Sep 2012
              • 1746
              • Country: Belgium
              #36
              monday i'm going to work on the car again and check some things like are my coolantpipes open from turbo
              i also place a heatcover over the exhaust manifold and change my oiltemp sender
              maybe move my oil and coolantpipes from turbo a little bit
              i also thought maybe place a heat exchanger on the oilfilterhouse from a vw,it's easy to place and put it in series with the coolant pipe from turbo
              i think this help for my oiltemp
              you will hear the results next week
              TWINCHARGED power,zero lag
              AEM W/M injection
              • quattro-nick
                • Sep 2012
                • 1746
                • Country: Belgium
                #37
                Today i have placed a turbopamper that I bought on ebay.de and made a heatcover for the exhaust manifold, it is attached around the manifold with springs
                (the material was originally a large turbo pamper from a truck that I have adapted)
                I also changed my water lines,the first piece on the turbo begins with a steel pipe for the heat around the turbo
                I had a dump valve placed from 034 motorsport but was not satisfied with the flute noise that it made so I put back the origionele dumpvalve
                i also placed a new oiltemp sender and temp sender behind the cylinder head
                Wednesday i go back on the road
                the last picture is taken under the manifold
                AEM W/M injection
                • bartieke210
                  • Sep 2013
                  • 290
                  • Country: Belgium
                  #38
                  Nice work Nick. I guess I should come see it
                  • quattro-nick
                    • Sep 2012
                    • 1746
                    • Country: Belgium
                    #39
                    it's almost ready bart,tomorrow i go tune my vems
                    AEM W/M injection
                    • bartieke210
                      • Sep 2013
                      • 290
                      • Country: Belgium
                      #40
                      Nice, so there will be flying a beast of a 5-stroker through the streets in Gompel
                      • quattro-nick
                        • Sep 2012
                        • 1746
                        • Country: Belgium
                        #41
                        after a few weeks a update!
                        because my oiltemp was a bit high i placed a coolant oilcooler from a golf on the oilfilterhouse.
                        i made some custom tubes and a heatshield for the downpipe
                        i made one connection on the back from the engine and one on the upper radiator hose
                        AEM W/M injection
                        • quattro-nick
                          • Sep 2012
                          • 1746
                          • Country: Belgium
                          #42
                          also i drilled extra holes in my sump protection for better sumpcooling
                          i made a extra air-ventilation in the front bumper for a better cooling for the ic
                          now the only thing i must do is to swap the mat sensor with a 1.8t one from golf 4 20v
                          and reprogram vems a bit and afterwords i can go back on the road for adjustmens in vems and can i see how it is with the oiltemp again
                          AEM W/M injection
                          • SE_30
                            • Apr 2010
                            • 1114
                            • Home: England Current: Israel
                            #43
                            Good initiative on the oil cooler, but did you not want to use a mocal item?
                            In the past on my mk2 golfs those coolers have a tendency to corrode internally and brake down, resulting in oil/ water mix. Giving the the impression that the head gasket has failed. I'd have bought a new one just to rule this out.
                            Good luck brining the temps down anyway. Hope it works for you.
                            Stuart
                            B2 90 quattro with boost
                            • quattro-nick
                              • Sep 2012
                              • 1746
                              • Country: Belgium
                              #44
                              thanks
                              if everything is okay, I'm going to place a new cooler
                              future work:-Polyurethane rubbers in the suspension
                              -rollcage
                              AEM W/M injection
                              • quattro-nick
                                • Sep 2012
                                • 1746
                                • Country: Belgium
                                #45
                                after all the changes I've made ​​over the past three weeks, I finally made a testdrive with the car and the results were present
                                oiltemp was max 110°c while i was tuning vems with ve-analyser !
                                i going to make more testdrives and if everything stays okay i make an appointment for the dyno
                                i can make more power with ignitiontable but that i leave for the tuner and play safe for now
                                i also ordered an rs2 70mm alu radiator by vidar skotheim and that will be my next job
                                AEM W/M injection
