Hi again guys
This time it's a question about taking the factory oil pump up to 7800 rpm which is where my rev limit is set at.
At the start I ran the engine with a totally standard oil system and it was quite obvious that the oil control was somewhat lacking. If the oil level was at the top of the dipstick it would usually end up in the catch tank and when the oil was low the engine would rattle the hydraulic lifters after a long pull at high revs. To stop this oil control problem I fitted a baffled/gated sump which stopped the oil ejection issue and allows me to keep oil to the top and stay there.
The problem now is when I use full revs on a long pull, say 2nd to 6th, I still get a rattle from the hydraulic lifters. The oil is full so I can only assume the pump is emptying the sump faster than the oil drains back, add that to surge from the acceleration and I have a problem. The obvious thing for me to do is increase the capacity of the sump but I remember years ago reading a post about someone modifying an oil pump or some part of the oil system to decrease the flow from the pump or increase the draining to the sump but can't find anything when I search.
Cheers Baz
Cheers Baz
