audi s2 3b catcam mounting
  • EMU_S2
    • Oct 2013
    • 90
    • Country: Denmark
    Hello. Ive bought some cat cams and i am actually just about to mount them right now. Yet ive run into some troubles. What would be the timing marks on the cam gears like there is some kind of timing marks on the stock wheels? The new ones are the following on the picture. Please help!
  • EMU_S2
    • Oct 2013
    • 90
    • Country: Denmark
    Picture of new cams and gears
    • Laaf
      • Oct 2010
      • 275
      You should have gotten a timing card with the cams. You set them by setting the crankshaft at a specified point and adjusting the lift on the cams per the timing card.
        On stock cams, the timing marks are on the back side of the chain sprockets so your photo doesn't help us.
        Cam and crank timing info:
        • EMU_S2
          • Oct 2013
          • 90
          • Country: Denmark
          I know they are. But not on these.
            Then I strongly recommend that you talk to the manufacturer of the cams and politely ask "WTF?"
            • EMU_S2
              • Oct 2013
              • 90
              • Country: Denmark
              Its cat cams. And that dosnt help me right now as i have no opportunity to call them in their opening time.
              • Erikk
                • Jul 2008
                • 103
                You need the timing card for your cams froms catcams, or calculated lift @ tdc for each camshaft. Those are listed at the catcams website
                Audi S2 Avant - 600whp
                • andy10v
                  • 5996
                  Use a dial gauge.
                  Sold ABY-stock
                  • EMU_S2
                    • Oct 2013
                    • 90
                    • Country: Denmark
                    Ok. Anybody that can explain to me how i know if the cams is timed right compared to the cam card above?? I think i got it about the piston placement and all. Just not how to match it with the cams.
                      Did you go here:
                      And then select a cam card like this (sport):
                        They have to timed with dial gauges as they are adjustable, they aren't drop in with marks unfortunately.
                          no wtf that is how they come, any adjustable cam is the same
                          Personally I would have bought schrick cams
                          • Biturbo
                            • Aug 2011
                            • 591
                            • Home: Lithuania Current: United Kingdom
                            That kind of dial gauges?I will need to do same soon,just waiting my cams arriving.
                            • will20v
                              • May 2007
                              • 391
                              if you dont know why you need to dial the cams in then dont even attempt it as it will all end in tears. Cams need to be dialed in properly by someone who knows what they are doing otherwise it will be wrong .
