audi s2 3b catcam mounting
The engineer tuner would tune cams with a dial gauge to the listed spec below. You really couldn't do this yourself, a competent engineer build or mechanic can do it locally.
It took hours to get mine done to spec
Contact cat cams directly for the correct information for lift at 1mm etc
Like has been said use the information from the website which tells you how much lift they should have at TDC. Set a dial gauge up on the lifter bucket and clock them until you achieve the required lift. Not a big job to do it can just be tricky to find a good place for the dial gauge to sit.Comment
if you dont know why you need to dial the cams in then dont even attempt it as it will all end in tears. Cams need to be dialed in properly by someone who knows what they are doing otherwise it will be wrong .
