Guys, my aux water pump is leaking coolant. having checked it out, the leak is coming from the plastic disc shaped thing at the end of the pump (leaking from the seam). the pump is otherwise working fine.
Speaking to the ever helpful VAGparts guys, it would appear the disc bit is only avaliable bought as a complete item with the pump attached, at a cost of £68.00 plus the dreaded.
Are there any alternitives, or is it possible to but the disc sepratly or repair the leak (perhaps some high temp silicone?, JB weld type stuff?), if not, i'll bite the bullet & go for new.
Any suggestions?
Darren.
Any suggestions?
Darren.
