My wife's 2.6 ABC cabriolet is still running poorly. The current symptom is that it starts and then stops straight away. After three of four times it runs, sometimes on all six sometimes not. On the road it seems to run fine even better if you drive it hard, which she never dos. It smells a bit rich on tick over. Had a mechanic look at it the other day
tried to read the codes but did not have the right cable . This has been tried before but for some unknown reason the ECU will not give up the codes. However we did find two things, one some corrosion in parts of the fuse box. the other strange thing when trying to find which cylinder was playing up we pulled the injectors of one at a time. The drivers side where all ok. The passenger side was very odd we could not determine which one made the difference, first it was the front then the back then the middle.
Then it started to idle well for a while then lumpy, took all three of and no difference.
Put them on again and it ran smooth. I have changed just about every thing on the car.
All the electrics plugs fuel filter FPR plugs and isv Two different sets of injectors.All improve things a little but this starting issue is getting worse.
If anyone has any ideas please let me know .it would be much appreciated.
. Just found out its an immobiliser problems.
I couldn't get it to work on my car or the wifes Passat the next day. I have got another lead on order from ebay so hopefully will be fault code reading again soon.
