Hi all,
Since a while my after run pump is constantly running. Thing is that I already had changed the 324 relay for the same problem, that fixed it. But now it's back...
So this afternoon I tested 2 things:
- unplugging the 2-wired temp switch on the water manifold -> no result
- unplugging the rad sensor -> no result
I now have the connector at the after run pump disconnected to prevent battery drainage. If I re-connect it, it starts immediatly.
So with the 324 already replaced I'm pretty curious where this live stream could
be coming from?
Thanks!
be coming from?
Thanks!
