324 is fried... why o why lol..
Aften run pump keeps running with new 324
Yeh, sorry.
Most of my posts that refer to wire colours are AAN colours. Many times they work for ABYs and ADUs but not always. As Nick has pointed out, the 3B (and maybe ABY/ADU) have different colours in this case.
Nick's diagram:
Thanks
Can't understand why it has toasted the 324 yet again. OK it probably had some work with the roadtrip in Corsica last year where we did quite a lot of stops on the way, and it was +30°C... but that should make it fry up again so soon.
There are 2 contact points that have cracked, will try resoldering them because the rest seems fine.Comment
you can see where the burned soldering points go? perhaps to one of the connecting pins?audi coupe quattro b2 2.2 20vt project (573hp-626nm)
TWINCHARGED power,zero lag
AEM W/M injectionComment
The component that burns out is the white 2 legged one.
It says ITT and 7PY on it's body, so it's something else than a resistance.
Probably also the component that fails on everybody's 324 relays...
If it would be known what it is exactly, replacing it could save the +90€ dealerprice.Comment
