This is my mate's B5 RS4. As you accellerate and the turbos spool up there's a squeesh noise, sounds like a boost leak. We've put bungs in and it will hold 1 bar for a while, dropping to .5 over say 30 secs. It's leaking down through the valves and rings and breathes gently out through the PCV valve. There's nothing that sounds like a leak.
There is a noise like a small exhaust leak coming from below the car, could this be it? I'm wondering if the EM to turbo joint is leaking on one side or the turbo to DP? Would this make a squeeshy sound? Need to get this sorted so PRJ can map it and I'm on holidays next week.
We've just sorted the valve timing and replaced all the valves in the PCV system and most of the hoses and it's flying on it's new hybrid turbos but now this new noise
