Vag-Com logs
  • pinotattt
    • Jan 2013
    • 174
    • Country: Malta
    Vag-Com logs
    I've been using Vag-com for a few years on my TT mainly and never encountered this.
    1st set of logs before potential re-map on the S2.
    Logged 031/115 in measuring blocks and rpm readings maxed out at 2500 rpms at wot 3/4th gear pulls. Log should be attached.
    I used the white/black pins and there,s a 3rd blue one.
    Friday 20 June 2014 09:33:47:04057 VCDS Version: Release 12.12.2 Data version: 20140212
    895 907 551 A 2.2l R5 MOTR.RHV HS D02
    Group A: '031 Group B: '115 Group C: Not Running
    RPM Inj. On Time Load Lambda Factor RPM Inj. On Time Load Lambda Factor
    TIME TIME TIME
    Marker STAMP /min ms % STAMP /min ms % STAMP
    0.28 810 1.55 6.2 0.969 0.03 790 1.55 6.2 0.969
    0.84 800 1.5 6.2 0.969 0.56 800 1.5 6.2 0.969
    1.42 790 1.6 6.2 0.969 1.12 770 1.55 6.2 0.969
    1.97 780 1.55 6.2 0.961 1.7 800 1.5 6.2 0.961
    2.55 780 1.55 6.2 0.961 2.25 780 1.55 6.2 0.961
    3.15 800 1.65 6.6 0.961 2.85 760 1.65 6.2 0.961
    3.72 830 1.5 6.2 0.961 3.44 860 1.55 6.2 0.961
    4.28 820 1.5 6.2 0.961 4 790 1.5 6.2 0.961
    4.85 810 1.55 6.2 0.961 4.56 810 1.5 6.2 0.961
    5.44 810 1.5 6.2 0.969 5.15 830 1.5 6.2 0.969
    6.02 810 1.55 6.2 0.969 5.72 790 1.55 6.2 0.969
    6.59 800 1.55 6.2 0.969 6.29 820 1.5 6.2 0.969
    7.21 790 1.55 6.2 0.961 6.9 800 1.55 6.2 0.961
    7.8 780 1.6 6.2 0.961 7.5 770 1.6 6.2 0.961
    8.36 790 1.6 6.2 0.961 8.08 800 1.6 6.2 0.961
    8.92 830 1.55 6.2 0.961 8.64 830 1.6 6.2 0.961
    9.5 810 2.85 17.2 0.969 9.22 830 1.55 6.2 0.961
    10.08 1580 2.15 55.4 0.977 9.78 1330 3 70.2 0.969
    10.67 1410 2.7 50.7 0.977 10.39 1470 2.55 51.1 0.977
    11.26 1450 2.15 43.3 0.984 10.97 1430 2.55 49.9 0.984
    11.83 1360 2.35 40.6 0.984 11.54 1400 2.25 40.6 0.984
    12.41 1320 2.5 41 0.977 12.12 1330 2.45 37.8 0.984
    12.98 1520 2.85 53 0.969 12.7 1410 2.45 44.9 0.977
    13.57 1810 3.35 0 0.977 13.28 1660 3.35 24.2 0.969
    14.16 2010 1.1 21.1 0.977 13.87 1980 3.2 73.7 0.977
    14.73 1730 1.15 19.1 0.977 14.44 1900 0.75 20.3 0.977
    15.3 1240 3.2 35.9 0.969 15.01 1550 1.75 19.1 0.977
    15.88 1150 4.3 0 0.969 15.6 1120 4.45 0 0.969
    16.47 1320 4.25 0 0.984 16.18 1220 4.25 0 0.977
    17.05 1470 4.15 0 0.992 16.76 1390 4.2 0 0.984
    17.65 1600 4 0 1 17.33 1550 4.1 0 0.992
    18.25 1680 1.05 2.3 0.984 17.94 1650 1.6 0.8 0.984
    18.83 1300 1.5 0.4 0.984 18.54 1490 1.35 1.2 0.984
    19.4 1030 1.45 0 0.977 19.1 1110 1.4 0 0.977
    20.01 960 1.4 0 0.969 19.69 970 1.3 0 0.969
    20.59 910 1.5 0 0.961 20.3 930 1.45 0 0.961
    21.16 840 1.55 0 0.953 20.87 880 1.5 0 0.953
    21.72 790 1.65 0 0.945 21.44 830 1.6 0 0.945
    22.3 730 1.8 0 0.938 22 780 1.7 0 0.938
    22.88 710 2.5 0 0.93 22.59 700 2.05 0 0.93
    23.46 700 3.25 3.1 0.938 23.17 680 3 0 0.93
    24.01 720 3.4 0 0.953 23.74 700 3.5 0 0.945
    24.58 750 3.05 16 0.969 24.3 740 3.35 3.9 0.961
    25.15 760 2.65 1.6 0.984 24.88 760 2.95 11.7 0.977
    25.72 790 2.4 1.6 0.977 25.44 780 2.55 1.6 0.984
    26.28 790 2.1 1.2 0.977 25.99 790 2.25 1.2 0.977
    26.86 720 7.35 2.7 0.969 26.56 780 2.05 1.2 0.977
    27.41 860 4.65 0 0.969 27.13 890 4.4 0 0.969
    28 930 4.7 0 0.977 27.71 890 4.65 0 0.977
    28.56 1030 4.8 0 0.984 28.28 970 4.8 0 0.984
    29.15 1130 5 0 0.992 28.84 1070 4.9 0 0.992
    29.73 1210 1.6 0 0.992 29.44 1190 5.05 0 1
    30.32 1150 1.6 0.4 0.992 30.01 1200 1.7 0.4 0.992
    30.88 1100 1.3 0 0.992 30.6 1150 1.5 0 0.992
    31.46 940 1.15 0 0.984 31.17 1030 1.15 0 0.984
    32.04 860 1.4 0 0.977 31.75 890 1.3 0 0.984
    32.64 820 1.5 0 0.969 32.33 830 1.4 0 0.977
    33.21 770 1.5 0 0.969 32.92 760 1.5 0 0.969
    33.82 700 1.85 0 0.961 33.52 770 1.65 0 0.961
    34.4 720 2.3 0 0.953 34.12 680 2 0 0.953
    35 720 3 0 0.945 34.7 700 2.7 0 0.953
    35.6 740 2.9 0.8 0.961 35.31 720 3.05 2 0.945
    36.19 780 2.45 0 0.961 35.9 760 2.8 0 0.961
    36.81 790 2.15 0 0.961 36.48 780 2.25 0.4 0.961
    37.42 790 2 0 0.953 37.14 800 2.05 0 0.953
    38 790 1.9 0.4 0.953 37.7 790 1.95 0.4 0.953
    38.61 780 1.95 0.8 0.953 38.32 780 1.9 0.8 0.953
    39.2 750 1.95 1.2 0.953 38.9 770 1.95 1.2 0.953
    39.76 750 2 1.6 0.953 39.47 770 2 1.6 0.953
    40.32 750 2 1.6 0.945 40.04 760 2 2 0.953
    40.88 740 2.25 2.3 0.945 40.6 750 2.15 2 0.945
    41.45 760 2.35 2.7 0.945 41.16 750 2.3 2.3 0.945
    42.04 760 2.15 2.7 0.945 41.74 760 2.25 3.1 0.945
    42.64 770 2 2.7 0.945 42.34 770 2.1 3.1 0.945
    43.2 800 4.25 0 0.953 42.93 810 4.7 0 0.945
    43.78 920 4.35 0 0.969 43.5 880 4.35 0 0.953
    44.37 1030 4.6 0 0.977 44.09 970 4.5 0 0.977
    44.94 1130 4.8 0 0.984 44.66 1070 4.7 0 0.984
    45.49 1240 5 0 1 45.22 1180 4.85 0 0.992
    46.08 1350 5.15 0 1 45.79 1290 5.05 0 1
    46.63 1470 5.3 0 1 46.36 1410 5.2 0 1
    47.2 1600 5.4 0 1 46.92 1540 5.4 0 1
    47.8 1730 5.45 0 1 47.5 1670 5.45 0 1
    48.39 1900 5.55 0 1 48.1 1820 5.5 0 1
    48.98 2060 5.7 0 1 48.69 1980 5.65 0 1
    49.56 2220 6 0 1 49.27 2150 5.85 0 1
    50.15 2430 6.4 0 1 49.86 2300 6.15 0 1
    50.74 2550 7.15 0 1 50.43 2500 6.7 0 1
    51.33 2550 8.3 0 1 51.03 2550 7.7 0 1
    51.94 2550 8.7 0 1 51.64 2550 8.7 0 1
    52.56 2550 8.8 0 1 52.25 2550 8.75 0 1
    53.21 2550 8.7 0 1 52.89 2550 8.7 0 1
    53.88 2550 8.5 0 1 53.55 2550 8.5 0 1
    54.58 2550 8.15 0 1 54.24 2550 8.35 0 1
    55.31 2550 8.2 0 1 54.94 2550 8.15 0 1
    56.09 2550 8 0 1 55.71 2550 8.15 0 1
    56.85 2550 7.8 0 1 56.46 2550 7.95 0 1
    57.64 2550 7.6 0 1 57.24 2550 7.6 0 1
    58.45 2550 7.5 0 1 58.03 2550 7.6 0 1
    59.31 2550 7.3 0 1 58.88 2550 7.4 0 1
    60.2 2550 6.95 0 1 59.74 2550 7 0 1
    61.19 2550 6.65 0 1 60.68 2550 6.7 0 1
    62.22 2550 6.3 0 1 61.69 2550 6.45 0 1
    63.37 2550 6.05 0 1 62.78 2550 6.15 0 1
    64.43 2550 0.95 0 0.992 63.94 2550 1.2 0 1
    65.21 2550 0.35 0 0.992 64.86 2550 0.5 0 0.992
    65.87 2550 0.3 0 0.992 65.52 2550 0.3 0 0.992
    66.53 2550 0.3 0 0.992 66.2 2550 0.2 0 0.992
    67.15 2550 0.5 0 0.992 66.85 2550 0.45 0 0.992
    67.73 2550 0.6 0 0.992 67.45 2550 0.55 0 0.992
    68.31 2550 0.6 0 0.992 68.02 2550 0.6 0 0.992
    68.92 2550 0.7 0 0.992 68.62 2550 0.65 0 0.992
    69.52 2550 0.75 0 0.992 69.22 2550 0.75 0 0.992
    70.1 2550 0.8 0 0.992 69.81 2550 0.75 0 0.992
    70.67 2500 0.8 0 0.992 70.38 2530 0.8 0 0.992
    71.26 2430 0.8 0 0.992 70.97 2460 0.8 0 0.992
    71.85 2360 0.85 0 0.992 71.56 2400 0.85 0 0.992
    72.44 2230 0.9 0 0.992 72.14 2300 0.9 0 0.992
    73.03 2080 0.95 0 0.992 72.73 2150 0.95 0 0.992
    73.62 1930 1.05 0 0.992 73.33 2000 1 0 0.992
    74.22 1820 1.1 0 0.992 73.93 1870 1.05 0 0.992
    74.78 1760 1.1 0 0.992 74.5 1780 1.1 0 0.992
    75.36 1690 1.15 0 0.992 75.07 1720 1.15 0 0.992
    75.92 1630 1.05 0 0.992 75.64 1670 1.1 0 0.992
    76.48 1580 0.9 0 0.992 76.2 1610 0.95 0 0.992
    77.05 1520 1.1 0 0.992 76.76 1560 0.8 0 0.992
    77.62 1580 4.45 0 0.992 77.34 1520 5.55 0 0.992
    78.19 1670 4.7 0 0.992 77.9 1600 4.55 0 0.992
    78.76 1800 4.95 0 0.992 78.48 1740 4.85 0 1
    79.32 1930 5.15 0 0.992 79.04 1880 5.05 0 1
    79.93 2100 5.45 0 0.992 79.65 2010 5.3 0 0.992
    80.51 2260 5.85 0 0.992 80.22 2180 5.7 0 1
    81.15 2460 6.4 0 1 80.82 2360 6.1 0 0.992
  • pinotattt
    • Jan 2013
    • 174
    • Country: Malta
    Fresh logs- Is the atmospheric pressure actual boost?? How can I upload cvs files
    Group A: '001 Group B: '002 Group C: '009
    Engine Speed Coolant Temp Lambda Factor Ignition Timing Engine Speed Injector Duration Battery Voltage Atmos.Pressure RPM Inj. On Time Load Lambda Factor
    TIME Idle 770-830 RPM 70-106 deg C ~ 1.0 Idle 8-12 BTDC TIME RPM Pulse Width Ambient TIME
    Marker STAMP /min °C °BTDC STAMP /min ms V mbar STAMP /min ms %
    0.6 800 93.1 1.016 9.8 0.03 800 2.21 13.94 1007.6 0.3 800 1.5 6.2 0.797
    1.64 800 93.1 1.016 9.8 0.88 800 2.34 14.01 1007.6 1.31 830 1.5 6.2 0.797
    2.55 800 93.1 0.992 9.8 1.95 800 2.21 13.74 1007.6 2.25 810 1.5 6.2 0.797
    3.45 800 93.1 0.977 9.8 2.84 800 2.21 13.94 1007.6 3.14 800 1.5 6.2 0.797
    4.34 760 93.8 0.961 9.8 3.76 760 2.21 13.87 1007.6 4.05 780 1.55 6.2 0.797
    5.25 760 94.5 1 9.8 4.65 800 2.21 13.94 1007.6 4.96 810 1.5 6.2 0.789
    6.12 760 95.2 1.016 9.8 5.53 760 2.21 13.94 1007.6 5.82 790 1.55 6.2 0.789
    6.98 800 94.5 1.023 9.8 6.41 760 2.21 13.87 1007.6 6.7 780 1.55 6.2 0.797
    7.87 800 95.2 1.008 9.8 7.29 800 2.21 13.87 1007.6 7.58 810 1.5 6.2 0.797
    8.75 800 95.2 0.984 9.8 8.16 760 2.21 13.87 1007.6 8.46 750 1.55 6.2 0.797
    9.65 800 95.2 0.969 9.8 9.05 800 2.08 13.94 1007.6 9.35 820 1.5 6.2 0.797
    10.53 800 95.2 1.008 9.8 9.95 800 2.21 13.87 1007.6 10.24 810 1.5 6.2 0.797
    11.43 800 95.2 1 9.8 10.83 800 2.21 13.94 1007.6 11.14 810 1.5 6.2 0.797
    12.3 1680 95.2 1.023 23.3 11.71 760 4.03 13.87 1007.6 11.99 1110 3.25 0 0.813
    13.19 1200 95.2 1 5.3 12.59 1720 1.17 13.87 1007.6 12.89 1500 0.8 0 0.828
    14.04 760 95.2 1.008 9.8 13.47 1000 1.56 13.94 1007.6 13.75 840 1.25 5.5 0.836
    14.91 840 95.2 0.992 9.8 14.33 800 2.47 13.94 1007.6 14.62 850 1.5 6.2 0.836
    15.78 800 95.2 0.984 9.8 15.21 800 2.21 13.94 1007.6 15.5 800 1.5 6.2 0.828
    16.64 800 95.2 0.969 9.8 16.05 800 2.21 13.87 1007.6 16.36 810 1.5 6.2 0.828
    17.53 760 95.2 0.953 9.8 16.94 760 2.21 13.94 1007.6 17.24 780 1.5 6.2 0.828
    18.45 800 95.2 0.938 9.8 17.83 760 2.08 13.26 1007.6 18.14 680 1.8 6.6 0.821
    19.35 800 95.2 0.93 9.8 18.73 920 2.34 13.53 1007.6 19.03 900 1.65 6.6 0.821
    20.23 800 95.2 0.953 9.8 19.63 760 2.34 13.46 1007.6 19.92 780 1.75 6.6 0.813
    21.13 800 95.2 0.984 9.8 20.53 760 2.34 13.53 1007.6 20.83 790 1.65 6.6 0.805
    21.99 760 95.2 1.008 9.8 21.42 760 2.34 13.67 1007.6 21.71 780 1.6 6.2 0.805
    22.86 800 95.2 1.016 9.8 22.27 760 2.47 13.53 1007.6 22.57 800 1.6 6.2 0.805
    23.76 760 95.2 0.992 9.8 23.15 760 2.47 13.6 1007.6 23.46 780 1.65 6.6 0.805
    24.65 760 95.2 0.969 9.8 24.05 800 2.34 13.6 1007.6 24.35 810 1.55 6.2 0.805
    25.53 760 95.2 0.945 9.8 24.94 720 2.34 13.53 1007.6 25.24 770 1.65 6.6 0.805
    26.42 760 95.2 0.977 9.8 25.85 760 2.34 13.6 1007.6 26.14 750 1.7 6.6 0.797
    27.35 840 95.2 1.008 9.8 26.71 840 2.34 13.74 1007.6 27.03 850 1.6 6.2 0.797
    28.26 840 95.2 1.031 9.8 27.66 800 2.34 13.67 1007.6 27.95 830 1.6 6.2 0.797
    29.18 880 95.2 1 9.8 28.55 880 2.21 13.87 1007.6 28.87 890 1.45 6.2 0.805
    30.04 800 95.9 0.992 9.8 29.46 800 2.08 13.8 1007.6 29.74 820 1.5 6.2 0.805
    30.91 800 97.3 0.977 9.8 30.33 800 2.21 13.94 1007.6 30.62 810 1.55 6.2 0.797
    31.77 760 97.3 0.961 9.8 31.19 800 2.08 13.8 1007.6 31.48 790 1.55 6.2 0.797
    32.67 760 97.3 0.984 9.8 32.07 760 2.21 13.87 1007.6 32.39 760 1.6 6.2 0.797
    33.53 800 97.3 1 9.8 32.96 800 2.21 13.94 1007.6 33.25 810 1.55 6.2 0.789
    34.39 800 97.3 1.008 9.8 33.81 800 2.21 13.67 1007.6 34.11 800 1.5 6.2 0.789
    35.33 800 97.3 1.023 9.8 34.7 800 2.21 13.87 1007.6 35.02 800 1.5 6.2 0.797
    36.24 800 97.3 1.039 9.8 35.63 800 2.21 13.8 1007.6 35.95 810 1.45 6.2 0.797
    37.13 800 97.3 1.039 9.8 36.53 800 2.21 13.87 1007.6 36.84 800 1.5 6.2 0.797
    37.99 720 97.3 1.023 10.5 37.42 800 2.21 13.87 1007.6 37.71 800 1.45 6.2 0.805
    38.88 1760 97.3 1.047 27 38.3 1080 5.59 13.94 1007.6 38.59 1690 2.55 50.7 0.836
    39.77 1320 97.3 1.016 24 39.18 1600 3.64 13.87 1007.6 39.48 1480 2.2 44.1 0.844
    40.68 1240 97.3 0.922 23.3 40.06 1160 3.77 13.87 1007.6 40.37 1140 2.55 26.9 0.844
    41.57 1560 97.3 0.906 26.3 40.98 1360 2.99 13.87 1007.6 41.27 1460 2.3 39 0.836
    42.44 2040 96.6 0.906 28.5 41.87 1720 4.42 13.87 1007.6 42.16 1900 2.95 80 0.828
    43.34 2160 97.3 0.852 27 42.74 2200 3.51 13.87 1007.6 43.04 2310 1.45 71 0.821
    44.23 1280 96.6 1.008 13.5 43.64 1920 0.91 13.94 1007.6 43.93 1610 1.2 0 0.813
    45.09 1200 95.9 1 17.3 44.51 1120 4.55 14.01 1007.6 44.8 1190 3.7 0 0.836
    45.96 1400 95.2 0.984 21.8 45.37 1280 6.11 13.87 1007.6 45.66 1350 3.5 0 0.891
    46.84 1360 95.2 1 5.3 46.26 1400 2.21 13.94 1007.6 46.54 1550 0.8 11.3 0.914
    47.72 880 95.2 0.977 9.8 47.12 1120 1.69 13.87 1007.6 47.42 830 1.35 2.7 0.914
    48.6 760 95.2 0.961 9.8 48.02 800 2.47 13.8 1007.6 48.32 800 1.5 3.5 0.914
    49.46 720 95.2 0.945 12 48.88 720 2.47 13.8 1007.6 49.17 720 1.75 3.9 0.914
    50.32 720 95.2 1 14.3 49.74 680 3.64 14.01 1007.6 50.03 700 2.8 8.2 0.906
    51.21 1200 95.2 0.969 9.8 50.63 680 5.07 13.8 1007.6 50.92 830 2.55 4.3 0.922
    52.08 1000 95.2 0.945 9.8 51.51 1280 1.69 13.94 1007.6 51.8 1130 1.1 3.9 0.922
    52.95 760 95.2 0.938 9.8 52.37 920 1.95 14.01 1007.6 52.67 820 1.3 2 0.914
    53.82 840 95.2 0.93 9.8 53.24 760 2.47 13.94 1007.6 53.53 810 1.5 2 0.914
    54.68 800 95.2 0.922 9.8 54.1 840 2.08 13.87 1007.6 54.38 830 1.35 2 0.906
    55.54 760 95.2 0.922 9.8 54.98 760 2.08 14.01 1007.6 55.26 750 1.45 1.6 0.899
    56.4 760 95.9 0.914 9.8 55.84 800 2.21 13.87 1007.6 56.12 810 1.4 1.6 0.891
    57.26 800 95.9 0.906 9.8 56.68 720 2.08 13.94 1007.6 56.97 780 1.5 1.6 0.883
    58.14 1000 95.9 0.891 12.8 57.55 1120 2.86 14.08 1007.6 57.85 930 2.65 3.5 0.891
    59.03 1080 95.9 0.961 16.5 58.44 1040 2.73 13.87 1007.6 58.74 1060 1.7 2.3 0.883
    59.91 1080 96.6 1.016 15.8 59.32 1080 2.47 13.8 1007.6 59.6 1100 1.55 2.7 0.875
    60.8 960 97.3 1.023 13.5 60.19 1080 2.34 13.94 1007.6 60.48 1110 1.15 3.1 0.883
    61.69 800 97.3 1.016 10.5 61.09 960 1.56 13.87 1007.6 61.38 880 0.95 2.3 0.883
    62.58 640 97.3 1 10.5 62 720 1.82 13.87 1007.6 62.28 700 1.4 2.7 0.883
    63.42 840 97.3 0.953 11.3 62.86 680 3.77 13.87 1007.6 63.14 790 2.15 5.9 0.883
    64.31 800 97.3 0.961 9.8 63.7 880 2.47 13.87 1007.6 64 880 1.45 3.9 0.875
    65.17 720 97.3 0.969 10.5 64.59 760 2.21 13.87 1007.6 64.88 780 1.4 3.9 0.875
    66.1 760 97.3 1 11.3 65.47 720 2.6 13.94 1007.6 65.81 760 1.85 5.1 0.875
    67 920 97.3 1.008 9.8 66.38 800 2.6 14.01 1007.6 66.68 960 1.35 5.1 0.875
    67.88 680 97.3 0.992 10.5 67.28 840 2.08 13.87 1007.6 67.58 710 1.45 5.5 0.875
    68.74 840 97.3 0.961 9.8 68.16 800 3.25 13.87 1007.6 68.44 880 1.8 7 0.875
    69.62 760 97.3 0.93 9.8 69.06 760 2.6 14.08 1007.6 69.33 770 1.8 6.6 0.867
    70.5 880 97.3 0.953 9.8 69.91 760 2.47 13.94 1007.6 70.21 850 1.6 6.2 0.86
    71.37 800 97.3 0.969 9.8 70.78 880 2.08 14.01 1007.6 71.08 860 1.35 5.9 0.86
    72.22 800 97.3 0.977 9.8 71.65 800 2.08 13.94 1007.6 71.93 800 1.4 5.9 0.86
    73.1 800 97.3 0.977 9.8 72.51 800 2.21 13.94 1007.6 72.8 800 1.4 5.9 0.852
    73.98 800 97.3 0.969 9.8 73.38 800 2.21 13.94 1007.6 73.68 830 1.4 5.9 0.852
    74.84 760 97.3 0.953 9.8 74.27 800 2.08 14.01 1007.6 74.54 800 1.45 6.2 0.852
    75.72 760 97.3 0.953 9.8 75.14 800 2.08 13.74 1007.6 75.42 800 1.45 6.2 0.844
    76.6 760 97.3 0.938 9.8 76.01 760 2.21 13.8 1007.6 76.32 800 1.5 6.2 0.844
    77.48 760 97.3 0.953 9.8 76.88 760 2.21 13.87 1007.6 77.17 770 1.55 6.2 0.836
    78.38 680 97.3 0.977 10.5 77.8 800 2.21 14.01 1007.6 78.09 760 1.45 6.2 0.836
    79.24 960 97.3 0.984 9.8 78.67 760 3.25 13.46 1007.6 78.96 990 1.7 6.6 0.828
    80.18 800 97.3 1.008 9.8 79.54 880 2.08 13.6 1007.6 79.85 830 1.55 6.2 0.828
    81.05 760 97.3 1 9.8 80.46 800 2.47 13.6 1007.6 80.76 790 1.6 6.2 0.828
    81.94 760 97.3 0.977 9.8 81.34 760 2.34 13.67 1007.6 81.63 780 1.6 6.2 0.828
    82.86 800 97.3 0.953 9.8 82.24 760 2.34 13.6 1007.6 82.55 750 1.75 6.6 0.828
    83.76 760 97.3 0.93 9.8 83.18 840 2.34 13.53 1007.6 83.48 830 1.65 6.6 0.821
    84.62 840 97.3 0.961 9.8 84.04 720 2.47 13.4 1007.6 84.32 770 1.95 7.8 0.821
    85.52 800 97.3 1 9.8 84.91 840 2.47 13.46 1007.6 85.22 860 1.6 6.2 0.813
    86.42 800 97.3 1 9.8 85.82 800 2.47 13.6 1007.6 86.11 820 1.65 6.6 0.813
    87.31 800 97.3 0.984 9.8 86.7 800 2.34 13.67 1007.6 87 790 1.6 6.2 0.813
    88.19 800 97.3 0.961 9.8 87.6 800 2.21 13.8 1007.6 87.89 830 1.55 6.2 0.813
    89.08 800 97.3 0.945 9.8 88.49 800 2.21 13.94 1007.6 88.78 810 1.55 6.2 0.813
    89.95 800 97.3 0.961 9.8 89.37 760 2.21 13.87 1007.6 89.66 830 1.6 6.2 0.805
    90.85 800 97.3 0.977 9.8 90.25 800 2.21 13.8 1007.6 90.56 830 1.6 6.2 0.805
    91.76 840 97.3 1 9.8 91.14 800 2.21 13.74 1007.6 91.46 820 1.6 6.2 0.797
    92.62 840 97.3 0.984 9.8 92.07 840 2.21 13.8 1007.6 92.35 840 1.55 6.2 0.797
    93.5 800 97.3 0.969 9.8 92.92 800 2.21 13.87 1007.6 93.22 810 1.55 6.2 0.797
    94.38 760 97.3 0.969 9.8 93.79 760 2.21 13.87 1007.6 94.08 790 1.55 6.2 0.797
    95.28 760 97.3 1 9.8 94.68 760 2.21 13.87 1007.6 94.98 810 1.55 6.2 0.797
    96.12 800 97.3 1.008 9.8 95.56 800 2.21 13.87 1007.6 95.84 800 1.5 6.2 0.797
    97 800 97.3 1.023 9.8 96.41 800 2.21 13.87 1007.6 96.71 800 1.5 6.2 0.797
    97.88 800 97.3 1.039 9.8 97.3 800 2.21 13.87 1007.6 97.59 810 1.5 6.2 0.797
    98.78 840 97.3 1.055 9.8 98.2 800 2.34 13.74 1007.6 98.5 830 1.45 6.2 0.797
    99.66 840 97.3 1.031 9.8 99.06 840 2.21 13.87 1007.6 99.36 840 1.45 6.2 0.805
    100.54 800 97.3 1.016 9.8 99.95 800 2.21 13.87 1007.6 100.26 800 1.45 6.2 0.805
    101.45 760 97.3 1 9.8 100.84 800 2.21 13.94 1007.6 101.15 810 1.45 6.2 0.805
    102.33 760 97.3 0.984 9.8 101.74 760 2.21 13.87 1007.6 102.04 800 1.5 6.2 0.805
    103.2 760 97.3 0.969 9.8 102.62 760 2.21 13.87 1007.6 102.9 770 1.55 6.2 0.805
    104.08 760 97.3 0.977 9.8 103.49 760 2.21 13.87 1007.6 103.78 760 1.55 6.2 0.805
    104.96 800 97.3 0.992 9.8 104.36 800 2.21 13.8 1007.6 104.66 800 1.5 5.9 0.821
    105.82 800 97.3 1.008 9.8 105.25 800 2.21 14.01 1007.6 105.54 810 1.5 5.5 0.836
    106.68 840 97.3 1 9.8 106.11 840 2.21 13.94 1007.6 106.4 840 1.45 5.1 0.844
    107.55 800 97.3 0.992 9.8 106.98 840 2.21 13.8 1007.6 107.26 840 1.35 3.9 0.867
    108.41 800 97.3 0.977 9.8 107.84 800 2.21 13.87 1007.6 108.12 810 1.4 3.5 0.883
    109.28 800 97.3 0.969 9.8 108.7 800 2.21 13.87 1007.6 109 840 1.4 3.1 0.899
    110.18 800 97.3 0.953 9.8 109.58 800 2.21 13.74 1007.6 109.88 830 1.4 2.3 0.914
    111.06 800 97.3 0.945 9.8 110.49 800 2.21 13.8 1007.6 110.77 840 1.4 2 0.938
    111.91 800 97.3 0.938 9.8 111.35 800 2.21 13.8 1007.6 111.63 830 1.4 1.6 0.953
    112.76 800 97.3 0.922 9.8 112.18 800 2.21 13.87 1007.6 112.47 830 1.4 0.8 0.961
    113.64 800 97.3 0.914 9.8 113.07 800 2.34 13.87 1007.6 113.36 830 1.4 0.4 0.977
    114.55 840 97.3 0.906 9.8 113.93 800 2.21 13.87 1007.6 114.24 830 1.35 0 1
    115.42 800 97.3 0.891 9.8 114.84 800 2.34 13.74 1007.6 115.12 810 1.4 0 1
    116.3 800 97.3 0.883 9.8 115.7 800 2.34 13.8 1007.6 115.99 810 1.4 0 1
    117.18 800 97.3 0.875 9.8 116.58 800 2.21 13.67 1007.6 116.88 800 1.45 0 1
    118.08 760 97.3 0.86 9.8 117.47 800 2.21 13.8 1007.6 117.78 790 1.4 0 1
    118.98 800 97.3 0.844 9.8 118.38 760 2.47 13.74 1007.6 118.67 780 1.55 0 1
    119.88 760 97.3 0.828 9.8 119.28 800 2.21 13.8 1007.6 119.58 810 1.45 0 1
    120.78 760 97.3 0.813 9.8 120.16 760 2.21 13.94 1007.6 120.46 800 1.5 0 1
    121.69 760 97.3 0.789 11.3 121.07 720 2.21 13.74 1007.6 121.37 750 1.65 0 1
    122.56 800 97.3 0.758 9.8 121.97 880 2.34 13.74 1007.6 122.26 830 1.6 0 1
    123.44 800 97.3 0.782 9.8 122.86 800 2.21 13.87 1007.6 123.15 800 1.6 0 1
    124.33 760 97.3 0.805 11.3 123.74 760 2.21 12.85 1007.6 124.04 680 1.85 0 1
    125.22 880 97.3 0.844 9.8 124.63 920 2.6 13.6 1007.6 124.92 960 1.5 0 1
    126.09 840 97.3 0.852 9.8 125.51 840 2.34 13.46 1007.6 125.8 860 1.55 0 1
    126.98 760 97.3 0.836 9.8 126.39 840 2.21 13.4 1007.6 126.69 810 1.5 0 1
    127.86 760 97.3 0.813 9.8 127.28 760 2.34 13.74 1007.6 127.57 780 1.6 0 1
    128.71 760 97.3 0.789 10.5 128.15 760 2.34 13.67 1007.6 128.43 770 1.6 0 1
    129.62 760 97.3 0.766 9.8 129 800 2.34 13.4 1007.6 129.31 790 1.65 0 1
    130.51 800 97.3 0.782 9.8 129.92 760 2.21 13.33 1007.6 130.21 740 1.8 0 1
    131.38 800 97.3 0.805 9.8 130.8 840 2.34 13.67 1007.6 131.09 820 1.6 0 1
    132.27 800 97.3 0.828 9.8 131.68 800 2.34 13.67 1007.6 131.98 800 1.6 0 1
    133.17 1120 97.3 0.782 12 132.57 760 2.6 13.74 1007.6 132.88 890 2.65 0 1
    134.02 1000 97.3 0.813 15.8 133.46 1200 2.34 13.74 1007.6 133.75 1120 1.75 0 1
    134.9 920 97.3 0.86 18 134.32 1000 3.38 13.94 1007.6 134.61 990 2.3 0 1
    135.76 920 97.3 0.782 19.5 135.18 920 3.64 13.8 1007.6 135.47 900 2.7 0 1
    136.64 1360 97.3 0.938 23.3 136.06 1040 5.46 13.8 1007.6 136.35 1210 2.65 0 1
    137.5 1880 97.3 0.821 26.3 136.93 1560 4.94 13.8 1007.6 137.21 1740 2.8 0 1
    138.38 1440 97.3 0.828 22.5 137.79 1800 1.17 13.87 1007.6 138.09 1630 0.85 0 1
    139.22 640 97.3 0.836 18.8 138.66 1240 1.56 13.87 1007.6 138.94 980 1.2 0 1
    140.12 720 97.3 1 16.5 139.5 640 7.54 14.08 1007.6 139.81 700 4.2 0 1
    141.01 840 97.3 1 14.3 140.43 760 7.8 14.01 1007.6 140.72 810 3.85 0 1
    141.9 920 97.3 1 12 141.3 880 7.67 13.67 1007.6 141.61 910 3.85 0 1
    142.77 960 97.3 0.945 12.8 142.2 960 3.9 14.01 1007.6 142.48 990 1.7 0 1
    143.66 920 97.3 0.922 9.8 143.07 960 2.34 13.94 1007.6 143.36 960 1.4 0 1
    144.52 920 97.3 0.891 10.5 143.95 920 2.34 13.87 1007.6 144.23 910 1.95 0 1
    145.38 1080 97.3 1 12.8 144.81 960 9.88 13.8 1007.6 145.09 1040 4.85 0 1
    146.3 1240 97.3 1 15 145.67 1120 10.27 14.01 1007.6 145.98 1190 5.15 0 1
    147.16 1400 97.3 1 13.5 146.59 1280 10.79 13.74 1007.6 146.88 1360 5.3 0 1
    148.02 1560 97.3 1 13.5 147.44 1440 10.92 13.74 1007.6 147.73 1520 5.5 0 1
    148.91 1760 97.3 1 11.3 148.32 1640 11.18 13.74 1007.6 148.61 1720 5.6 0 1
    149.78 1960 97.3 1 13.5 149.2 1840 11.44 13.67 1007.6 149.5 1900 5.7 0 1
    150.68 2200 97.3 1 13.5 150.08 2040 11.7 13.8 1007.6 150.39 2150 5.95 0 1
    151.59 2440 97.3 1 12 150.99 2280 12.48 13.87 1007.6 151.29 2380 6.4 0 1
    152.48 2760 97.3 1 10.5 151.89 2560 14.17 13.8 1007.6 152.17 2550 7.3 0 1
    153.41 3120 97.3 1 7.5 152.77 2880 18.46 13.53 1007.6 153.09 2550 9.1 0 1
    154.33 3520 97.3 1 8.3 153.72 3240 21.06 13.67 1007.6 154.03 2550 9.2 0 1
    155.33 3880 97.3 1 10.5 154.66 3640 20.93 13.67 1007.6 154.99 2550 8.9 0 1
    156.39 4280 97.3 1 14.3 155.69 4000 20.41 13.74 1007.6 156.03 2550 8.7 0 1
    157.53 4760 97.3 1 16.5 156.75 4440 19.37 13.67 1007.6 157.14 2550 8.5 0 1
    158.67 5160 97.3 1 18.8 157.9 4840 18.85 13.6 1007.6 158.28 2550 8.15 0 1
    159.82 5560 97.3 1 18.8 159.05 5280 17.68 13.67 1007.6 159.43 2550 7.85 0 1
    161.07 5920 97.3 1 20.3 160.23 5640 17.42 13.6 1007.6 160.64 2550 7.6 0 1
    162.44 6320 97.3 1 21.8 161.51 6040 17.29 13.67 1007.6 161.96 2550 7.2 0 1
    163.97 6680 97.3 1 23.3 162.94 6440 16.12 13.6 1007.6 163.45 2550 6.75 0 1
    165.72 6960 97.3 1 23.3 164.53 6760 15.08 13.67 1003.2 165.12 2550 6.3 0 1
    167.58 7080 96.6 0.969 28.5 166.36 7080 14.43 13.67 1003.2 166.99 2550 6.15 0 1
    168.67 5640 96.6 1 20.3 167.97 6520 2.34 13.94 1003.2 168.32 2550 0.7 0 0.992
    169.7 4320 96.6 1 20.3 169 5240 2.34 13.8 1003.2 169.35 2550 0.25 0 0.992
    170.61 3240 95.9 1 20.3 170.02 4000 2.34 13.94 1003.2 170.31 2550 0.1 0 0.992
    171.52 2000 95.9 1 20.3 170.91 2880 2.34 13.87 1003.2 171.22 2490 0.6 0 0.992
    172.41 1760 95.2 1 15 171.82 1760 2.34 13.8 1003.2 172.11 1800 0.9 0 0.992
    173.31 1640 95.2 1 10.5 172.72 1720 2.34 14.01 1003.2 173.01 1680 0.95 0 0.992
    174.19 1600 95.2 1.023 10.5 173.61 1600 1.95 14.01 1003.2 173.9 1600 1.1 0 0.992
    175.09 1480 95.2 1 4.5 174.48 1560 1.56 14.01 1003.2 174.79 1540 0.75 0 0.992
    175.98 1320 95.2 1 0 175.39 1440 1.56 14.01 1003.2 175.69 1430 0.6 0 0.992
    176.87 1120 95.2 1.016 9.8 176.28 1240 1.17 14.01 1003.2 176.58 1200 0.7 0.8 0.992
    177.77 1000 95.2 1.008 9.8 177.18 1040 1.43 13.87 1003.2 177.47 1030 0.85 0.8 1
    178.64 680 95.2 1 13.5 178.05 920 1.69 14.01 1003.2 178.36 780 1.05 1.2 1
    179.51 1480 95.2 0.945 10.5 178.92 840 16.12 14.01 1003.2 179.22 1410 1.5 7.4 1
    180.4 1040 95.2 0.93 9.8 179.81 1360 1.56 14.08 1003.2 180.11 1190 0.9 3.1 1
    181.27 720 95.2 0.922 10.5 180.68 880 1.69 14.01 1003.2 180.97 780 1.25 1.6 0.992
    182.16 1080 95.2 0.906 9.8 181.58 800 2.6 14.01 1003.2 181.87 990 1.35 1.6 0.984
    183.05 1000 95.2 0.899 9.8 182.46 1040 1.69 14.08 1003.2 182.76 1030 1.05 1.2 0.977
    183.97 880 95.2 0.899 9.8 183.36 960 1.56 14.01 1007.6 183.65 930 1.05 1.2 0.969
    184.84 800 95.2 0.899 9.8 184.26 840 1.69 14.01 1007.6 184.54 840 1.1 0.8 0.961
    185.69 720 95.9 0.899 10.5 185.12 760 1.82 14.08 1007.6 185.42 750 1.2 0.8 0.953
    186.6 720 96.6 0.883 11.3 185.99 680 2.34 13.94 1007.6 186.3 710 1.75 0.8 0.945
    187.5 760 97.3 0.852 10.5 186.88 720 2.99 14.01 1007.6 187.2 770 1.95 0.8 0.93
    188.38 800 97.3 0.899 9.8 187.78 760 2.34 13.94 1007.6 188.07 810 1.55 0.4 0.922
    189.28 760 97.3 0.93 10.5 188.68 760 2.47 14.01 1007.6 188.99 760 1.55 0.4 0.914
    190.16 760 97.3 0.953 10.5 189.58 720 2.47 13.8 1007.6 189.87 760 1.65 0.4 0.906
    191.04 760 97.3 0.984 9.8 190.45 720 2.86 14.08 1007.6 190.76 770 1.7 0.4 0.899
    191.9 800 97.3 1.008 9.8 191.34 800 2.6 13.87 1007.6 191.62 800 1.6 0.4 0.906
    192.78 800 97.3 1.031 9.8 192.2 800 2.73 13.74 1003.2 192.5 800 1.6 0 0.93
    193.68 800 97.3 1.023 9.8 193.08 800 2.6 13.94 1003.2 193.37 830 1.5 0.4 0.938
    194.56 800 97.3 1.008 9.8 193.98 800 2.6 13.94 1003.2 194.26 820 1.45 0.8 0.938
    195.44 800 97.3 0.977 10.5 194.84 800 2.6 13.8 1003.2 195.14 810 1.85 1.2 0.938
    196.33 1160 97.3 1 13.5 195.74 960 6.63 13.94 1003.2 196.04 1090 3.85 0 0.953
    197.25 1600 97.3 1 17.3 196.65 1320 8.32 13.94 1003.2 196.95 1460 4.45 0 0.977
    198.15 2000 97.3 1 18.8 197.56 1720 9.49 13.87 1003.2 197.86 1880 4.95 0 1
    199.04 2480 97.3 1 18 198.46 2160 10.4 13.94 1007.6 198.75 2340 5.45 0 1
    199.98 3120 97.3 1 15 199.35 2680 12.35 13.87 1007.6 199.67 2550 6.75 0 1
    200.96 3960 97.3 1 9 200.29 3360 20.02 13.87 1007.6 200.62 2550 9.75 0 1
    202.09 4840 97.3 1 15.8 201.33 4240 21.58 13.74 1007.6 201.71 2550 8.8 0 1
    203.29 5640 97.3 1 18.8 202.47 5120 19.5 13.74 1007.6 202.86 2550 8.25 0 1
    204.7 6520 97.3 1 21.8 203.71 6000 17.94 13.74 1007.6 204.17 2550 7.5 0 1
    206.41 7120 97.3 1 24.8 205.24 6800 15.86 13.74 1003.2 205.85 2550 6.4 0 1
    207.76 5080 97.3 0.883 25.5 206.96 7120 2.73 13.94 1003.2 207.39 2550 0.5 0.8 0.992
    208.9 5480 97.3 1 16.5 208.14 5240 19.5 13.67 1003.2 208.52 2550 8.35 0 0.992
    210.12 5880 97.3 1 18 209.31 5640 18.46 13.67 1003.2 209.71 2550 7.9 0 0.992
    211.41 6000 97.3 0.953 23.3 210.56 6000 17.68 13.74 1003.2 210.98 2550 7.45 0 1
    212.48 5440 97.3 1 20.3 211.77 5920 2.08 14.01 1003.2 212.14 2550 0.55 0 0.984
    213.45 4960 97.3 1 20.3 212.81 5280 2.08 14.01 1003.2 213.12 2550 0.9 0 0.984
    214.46 4680 97.3 1 20.3 213.79 4840 2.08 14.08 1003.2 214.13 2550 0.7 0 0.984
    215.45 4520 97.3 1 20.3 214.79 4600 2.08 14.08 1003.2 215.11 2550 0.35 0 0.984
    216.45 4320 97.3 1 20.3 215.8 4440 2.08 14.14 1003.2 216.12 2550 0.35 0 0.984
    217.44 4120 97.3 1 20.3 216.79 4240 2.08 14.01 1003.2 217.13 2550 0.4 0 0.984
    218.38 3960 97.3 1 20.3 217.76 4080 2.08 14.08 1003.2 218.07 2550 0.45 0 0.984
    219.33 3800 97.3 1 20.3 218.68 3960 2.08 14.08 1003.2 219.02 2550 0.5 0 0.984
    220.28 3640 97.3 1 20.3 219.63 3760 2.08 14.01 1003.2 219.94 2550 0.5 0 0.984
    221.19 3480 96.6 1 20.3 220.58 3600 2.08 14.08 1003.2 220.89 2550 0.55 0 0.984
    222.09 3320 96.6 1 20.3 221.49 3440 2.08 13.94 1003.2 221.79 2550 0.55 0 0.984
    222.98 3200 96.6 1 20.3 222.38 3240 2.08 14.08 1003.2 222.68 2550 0.6 0 0.992
    223.9 3040 95.9 1 20.3 223.27 3120 2.08 14.21 1003.2 223.58 2550 0.65 0 0.984
    224.81 2880 95.9 1 20.3 224.21 3000 2.08 14.14 1003.2 224.51 2550 0.65 0 0.984
    225.67 2720 95.2 1 20.3 225.1 2800 2.08 14.08 1003.2 225.38 2550 0.7 0 0.992
    226.55 2600 95.2 1 20.3 225.96 2720 2.08 14.01 1003.2 226.24 2550 0.7 0 0.992
    227.45 2480 95.2 1 20.3 226.86 2560 2.08 14.14 1003.2 227.14 2530 0.75 0 0.984
    228.35 2480 95.2 0.977 25.5 227.77 2440 3.25 14.08 1003.2 228.07 2490 3.3 1.6 0.992
    229.29 2480 95.2 0.805 21.8 228.68 2520 7.15 14.08 1003.2 229.01 2530 2.2 16.8 0.992
    230.16 2200 95.2 1 20.3 229.58 2440 1.69 14.01 1003.2 229.86 2340 0.6 0 0.984
    231.04 1840 95.2 1 14.3 230.47 2080 1.69 14.08 1003.2 230.75 1980 0.95 0 0.984
    231.92 1240 95.2 1 4.5 231.33 1720 1.69 14.08 1003.2 231.64 1520 1.1 0 0.984
    232.79 1040 95.2 1.008 9.8 232.21 1200 1.95 14.01 1003.2 232.5 1130 1.15 2 0.984
    233.7 880 95.2 1 9.8 233.09 960 2.08 13.94 1003.2 233.39 940 1.2 1.6 0.992
    234.58 840 95.2 0.984 9.8 234 840 2.21 14.08 1003.2 234.29 860 1.25 2 0.984
    235.47 840 95.2 0.977 9.8 234.89 800 2.21 14.08 1003.2 235.18 840 1.2 2.3 0.984
    236.38 800 95.2 0.969 9.8 235.76 800 2.08 13.87 1003.2 236.06 800 1.25 2.7 0.984
    237.28 760 95.2 0.961 9.8 236.67 800 2.08 13.94 1003.2 236.98 800 1.2 3.1 0.984
    238.13 760 95.2 0.961 9.8 237.57 760 2.08 14.08 1003.2 237.85 750 1.2 3.5 0.977
    238.99 800 95.2 0.953 9.8 238.41 800 2.08 14.01 1007.6 238.69 830 1.2 3.9 0.977
    239.87 760 95.2 0.953 9.8 239.29 760 2.08 14.08 1007.6 239.58 770 1.2 4.3 0.969
    240.78 760 95.2 0.945 9.8 240.16 760 1.95 14.08 1007.6 240.46 780 1.2 4.7 0.969
    241.64 760 95.2 0.945 9.8 241.06 720 2.08 14.01 1007.6 241.34 780 1.25 4.7 0.961
    242.52 760 95.2 0.945 9.8 241.94 760 1.95 14.08 1007.6 242.23 770 1.2 4.7 0.961
    243.4 760 95.2 0.938 9.8 242.82 760 1.95 13.94 1007.6 243.11 770 1.2 4.3 0.953
    244.29 760 95.2 0.961 9.8 243.7 760 1.95 14.08 1007.6 244 780 1.25 4.3 0.945
    245.17 760 95.2 0.969 9.8 244.57 760 2.08 14.01 1007.6 244.86 770 1.25 4.7 0.945
    246.06 800 95.2 0.977 9.8 245.46 800 2.08 13.87 1007.6 245.75 800 1.2 5.1 0.945
    246.96 800 95.2 0.969 9.8 246.37 800 1.95 14.08 1007.6 246.67 800 1.25 5.5 0.938
    247.86 800 95.2 0.961 9.8 247.26 800 1.95 14.01 1003.2 247.57 800 1.2 5.5 0.938
    248.74 800 95.2 0.961 9.8 248.14 800 1.95 14.01 1003.2 248.43 780 1.25 5.5 0.93
    249.63 800 95.2 0.953 9.8 249.04 800 1.95 14.01 1003.2 249.34 800 1.25 5.5 0.93
    250.52 800 95.2 0.953 9.8 249.93 760 1.95 13.8 1003.2 250.22 800 1.25 5.5 0.922
    251.39 760 95.2 0.961 9.8 250.82 800 1.95 14.08 1003.2 251.11 800 1.25 5.5 0.922
    252.23 760 95.2 0.969 9.8 251.67 760 2.08 14.08 1003.2 251.95 810 1.25 5.5 0.914
    253.1 800 95.2 0.961 9.8 252.52 760 2.08 14.08 1003.2 252.82 810 1.25 5.5 0.914
    254.01 800 95.2 0.961 9.8 253.39 800 1.95 14.08 1003.2 253.7 800 1.3 5.5 0.914
    254.86 760 95.2 0.953 9.8 254.29 800 2.08 13.94 1003.2 254.57 780 1.3 5.5 0.906
    255.77 800 95.2 0.953 9.8 255.15 800 2.08 14.01 1003.2 255.45 800 1.3 5.5 0.906
    256.66 760 95.2 0.945 9.8 256.06 800 1.95 13.94 1007.6 256.37 780 1.3 5.5 0.899
    257.5 800 95.2 0.945 9.8 256.94 800 1.95 14.01 1007.6 257.22 810 1.3 5.5 0.891
    258.36 800 95.2 0.938 9.8 257.78 760 1.95 13.94 1007.6 258.07 780 1.35 5.9 0.891
    259.26 760 95.2 0.938 9.8 258.66 800 1.95 13.94 1007.6 258.96 800 1.3 5.1 0.883
    260.13 760 95.2 0.945 9.8 259.55 760 1.95 14.01 1007.6 259.84 790 1.35 5.5 0.875
    261.03 760 95.2 0.938 9.8 260.43 760 1.95 13.94 1007.6 260.72 800 1.35 5.5 0.875
    261.93 800 96.6 0.938 9.8 261.33 760 2.08 13.94 1007.6 261.62 790 1.35 5.1 0.867
    262.85 800 96.6 0.961 9.8 262.22 760 1.95 14.01 1007.6 262.53 760 1.4 5.1 0.86
    263.75 760 97.3 0.961 9.8 263.15 800 1.95 13.94 1007.6 263.44 810 1.35 5.5 0.86
    264.63 800 97.3 0.961 9.8 264.03 800 2.08 14.01 1007.6 264.33 790 1.35 5.9 0.86
    265.52 800 97.3 0.953 9.8 264.92 800 1.95 14.01 1007.6 265.23 800 1.35 5.9 0.852
    266.39 760 97.3 0.953 9.8 265.81 760 1.95 14.01 1007.6 266.1 780 1.35 5.9 0.852
    267.28 760 97.3 0.945 9.8 266.68 800 1.95 13.94 1007.6 266.98 800 1.35 5.9 0.844
    268.14 760 97.3 0.969 9.8 267.57 760 1.95 13.94 1007.6 267.87 780 1.4 5.9 0.844
    269.02 760 97.3 0.961 9.8 268.44 800 1.95 13.87 1007.6 268.72 790 1.35 5.9 0.836
    269.89 760 97.3 0.953 9.8 269.31 800 1.95 14.01 1007.6 269.6 800 1.35 5.9 0.836
    270.76 800 97.3 0.945 9.8 270.18 760 2.08 14.01 1007.6 270.49 780 1.45 6.2 0.828
    271.64 760 97.3 0.961 9.8 271.04 760 1.95 13.87 1007.6 271.33 780 1.4 5.9 0.828
    272.53 800 97.3 0.969 9.8 271.95 760 1.95 14.01 1007.6 272.24 800 1.4 5.9 0.821
    273.43 760 97.3 0.969 9.8 272.83 800 1.95 13.94 1007.6 273.14 770 1.4 5.9 0.821
    274.33 720 97.3 0.969 12 273.74 760 1.95 14.01 1003.2 274.04 790 1.4 5.9 0.813
    275.22 920 97.3 0.938 9.8 274.63 680 2.6 13.46 1003.2 274.93 840 1.85 7.4 0.813
    276.1 760 97.3 0.953 9.8 275.51 840 1.95 13.6 1003.2 275.81 810 1.5 6.2 0.805
    277.02 800 97.3 0.969 9.8 276.41 800 2.08 13.6 1003.2 276.71 810 1.5 6.2 0.805
    277.94 760 97.3 0.992 9.8 277.33 800 2.08 13.8 1003.2 277.63 790 1.5 6.2 0.805
    278.84 760 97.3 0.969 9.8 278.25 800 2.08 13.6 1003.2 278.55 770 1.5 6.2 0.797
    279.72 720 97.3 0.953 12 279.13 800 2.08 13.8 1003.2 279.42 780 1.5 6.2 0.797
    280.64 760 97.3 0.945 9.8 280.05 760 2.21 13.8 1003.2 280.33 830 1.55 6.2 0.789
    281.53 720 97.3 0.922 12 280.94 760 2.08 13.74 1003.2 281.25 770 1.6 6.2 0.789
    282.43 760 97.3 0.93 9.8 281.83 760 2.08 13.8 1007.6 282.12 800 1.55 6.2 0.782
    283.31 760 97.3 0.953 9.8 282.73 760 2.08 13.74 1007.6 283.02 760 1.6 5.9 0.774
    284.19 800 97.3 0.977 9.8 283.61 800 2.08 13.67 1007.6 283.9 800 1.55 6.2 0.774
    285.06 840 97.3 1 9.8 284.48 800 2.08 13.74 1007.6 284.77 830 1.5 6.2 0.774
    285.95 800 97.3 0.984 9.8 285.36 840 1.95 13.94 1007.6 285.66 830 1.45 6.2 0.766
    286.83 800 98 0.969 9.8 286.25 800 1.95 13.94 1007.6 286.54 810 1.5 6.2 0.766
    287.73 760 98 0.953 9.8 287.13 800 1.95 13.87 1007.6 287.43 800 1.5 6.2 0.766
    288.65 760 98.7 0.945 9.8 288.04 760 1.95 13.94 1007.6 288.34 810 1.5 6.2 0.758
    289.52 800 98.7 0.984 9.8 288.95 760 2.08 13.94 1007.6 289.23 770 1.5 6.2 0.758
    290.41 760 98.7 1 9.8 289.83 800 1.95 14.01 1007.6 290.12 790 1.45 6.2 0.758
    291.31 760 98.7 1.016 9.8 290.7 760 2.08 13.74 1003.2 291 810 1.4 6.2 0.758
    292.21 800 98.7 1.031 9.8 291.61 760 2.08 13.87 1003.2 291.91 790 1.45 6.2 0.758
    293.08 1600 98.7 1.008 23.3 292.49 720 4.81 13.8 1003.2 292.78 1100 3.65 0 0.782
    293.98 1280 98.7 1.047 24 293.38 1440 3.64 13.94 1003.2 293.69 1370 2.85 49.5 0.813
    294.9 1520 98.7 0.938 25.5 294.29 1240 4.42 13.8 1003.2 294.59 1320 2.9 60.5 0.813
    295.76 1760 98.7 0.836 25.5 295.19 1680 3.38 13.94 1003.2 295.47 1820 1.8 52.3 0.805
    296.61 840 98.7 0.883 9 296.04 1480 1.43 13.94 1003.2 296.34 1180 0.9 9.8 0.797
    297.49 880 98.7 1 11.3 296.9 840 3.77 13.94 1007.6 297.19 910 3.85 0 0.805
    298.39 1080 98.7 1 14.3 297.79 920 6.24 14.08 1007.6 298.09 1020 3.6 0 0.875
    299.26 1240 98.7 0.969 17.3 298.69 1120 5.85 14.08 1007.6 298.98 1190 3.15 74.1 0.953
    300.13 1280 98 0.938 14.3 299.55 1240 1.95 13.94 1007.6 299.83 1270 1.3 3.5 0.953
    301.03 840 97.3 0.93 9.8 300.45 1200 1.95 13.87 1007.6 300.74 1030 1.25 1.2 0.953
    301.9 920 97.3 0.906 9.8 301.31 760 2.73 13.94 1007.6 301.61 810 1.9 1.2 0.945
    302.78 880 97.3 0.883 9.8 302.2 880 2.34 13.87 1007.6 302.49 910 1.55 0.8 0.938
    303.66 920 97.3 0.86 9.8 303.08 920 2.21 13.94 1003.2 303.37 910 1.5 0.8 0.922
    304.54 920 97.3 0.86 9.8 303.94 920 1.95 13.94 1003.2 304.23 940 1.4 0.8 0.914
    305.41 920 98 0.852 9.8 304.83 920 1.82 13.94 1003.2 305.11 950 1.35 0.4 0.899
    306.28 960 97.3 0.852 9.8 305.69 920 1.82 14.01 1003.2 305.99 970 1.35 0.4 0.891
    307.13 960 97.3 0.852 9.8 306.57 960 1.69 13.94 1003.2 306.85 970 1.25 0 0.875
    307.98 920 97.3 0.852 9.8 307.42 920 1.56 13.12 1003.2 307.7 970 1.2 0 0.86
    308.82 920 97.3 0.883 9.8 308.26 920 1.43 13.67 1003.2 308.55 950 1.15 0 0.852
    309.71 920 98 0.899 9.8 309.11 920 1.43 13.74 1003.2 309.42 930 1.15 0 0.844
    310.59 880 98 0.922 9.8 310.01 920 1.56 13.74 1003.2 310.3 920 1.15 0 0.828
    311.47 880 98 0.938 9.8 310.87 880 1.56 13.8 1003.2 311.17 900 1.15 0 0.828
    312.38 880 98.7 0.953 9.8 311.77 880 1.56 14.01 1003.2 312.08 900 1.1 0 0.821
    313.23 960 98.7 1 10.5 312.67 880 2.08 13.87 1003.2 312.95 860 5.05 0 0.828
    314.09 1160 98.7 1 13.5 313.52 1000 7.67 14.01 1003.2 313.8 1120 4.5 0 0.891
    314.96 1400 98.7 1 15.8 314.39 1240 9.1 13.94 1003.2 314.67 1330 4.95 0 0.953
    315.85 1640 98.7 1 12.8 315.25 1480 10.27 13.87 1003.2 315.56 1600 5.35 0 1
    316.71 1920 98.7 1 14.3 316.13 1760 11.05 13.8 1003.2 316.42 1850 5.55 0 1
    317.59 2200 98.7 1 13.5 316.99 2000 11.31 13.87 1003.2 317.29 2100 5.75 0 1
    318.47 2520 98.7 1 12.8 317.88 2280 12.09 13.8 1003.2 318.18 2430 6.25 0 1
    319.37 2880 98.7 1 10.5 318.78 2640 14.43 13.87 1003.2 319.07 2550 7.4 0 1
    320.28 3320 98.7 1 7.5 319.67 3040 19.76 13.74 1007.6 319.98 2550 9.45 0 1
    321.23 3760 98 1 9 320.59 3480 21.45 13.74 1007.6 320.9 2550 9.25 0 1
    322.26 4200 98 1 12 321.57 3960 21.45 13.74 1003.2 321.91 2550 8.9 0 1
    323.37 4720 97.3 1 15.8 322.61 4360 20.15 13.74 1003.2 322.99 2550 8.6 0 1
    324.5 5200 97.3 1 18 323.77 4840 19.24 13.6 1003.2 324.14 2550 8.3 0 1
    325.68 5640 97.3 1 18.8 324.88 5280 18.2 13.74 1003.2 325.27 2550 8 0 1
    326.93 6040 97.3 1 20.3 326.08 5760 17.94 13.67 1003.2 326.51 2550 7.6 0 1
    328.38 6440 97.3 1 22.5 327.4 6200 17.42 13.6 1003.2 327.88 2550 7.15 0 1
    329.98 6760 97.3 1 22.5 328.9 6600 16.12 13.74 1003.2 329.45 2550 6.7 0 1
    331.76 7120 97.3 1 23.3 330.54 6920 15.21 13.74 1003.2 331.13 2550 6.35 0 1
    333.49 7120 97.3 1 26.3 332.37 7240 14.56 13.67 1003.2 332.92 2550 5.75 0 1
    334.73 5440 97.3 0.821 30.8 333.92 6080 2.6 14.01 1003.2 334.32 2550 1.45 0 0.992
    335.77 4640 97.3 1 20.3 335.11 5120 0.91 14.08 1003.2 335.43 2550 0.8 0 0.977
    336.7 3520 97.3 1 20.3 336.09 4240 0.91 14.01 1003.2 336.4 2550 0.45 0 0.977
    337.67 4360 97.3 1 20.3 337.03 4040 0.91 14.01 1003.2 337.36 2550 0.4 0 0.977
    338.61 3760 96.6 1 20.3 337.99 4160 0.91 14.01 1003.2 338.31 2550 0.4 0 0.977
    339.48 3320 95.9 1 20.3 338.91 3600 0.91 14.08 1003.2 339.2 2550 0.5 0 0.977
    340.38 3040 95.2 1 20.3 339.79 3200 0.91 14.08 1003.2 340.08 2550 0.6 0 0.977
    341.25 2800 95.2 1 20.3 340.67 2960 0.91 14.08 1003.2 340.95 2550 0.65 0 0.984
    342.14 2640 95.2 1 20.3 341.57 2760 0.91 14.01 1003.2 341.85 2550 0.7 0 0.984
    343.01 2480 95.2 1 20.3 342.43 2560 0.91 14.08 1003.2 342.72 2510 0.8 0 0.977
    343.89 2400 95.2 1 20.3 343.31 2480 0.91 14.14 1003.2 343.6 2450 0.8 0 0.977
    344.79 2360 95.2 1 20.3 344.18 2400 0.91 14.01 1003.2 344.48 2380 0.8 0 0.984
    345.67 2240 95.2 1 20.3 345.09 2320 0.91 14.08 1003.2 345.38 2300 0.85 0 0.977
    346.57 2200 95.2 1 20.3 345.96 2240 0.91 14.08 1003.2 346.26 2220 0.85 0 0.984
    347.43 2120 95.2 1 18.8 346.86 2160 0.91 14.01 1003.2 347.14 2150 0.85 0 0.984
    348.3 2080 95.2 1.039 21 347.72 2120 2.08 14.08 1003.2 348 2120 1.4 0 0.992
    349.17 2120 95.2 0.899 29.3 348.59 2120 3.12 14.08 1003.2 348.88 2150 2.3 3.5 0.984
    350.09 2240 95.2 0.75 28.5 349.47 2160 4.55 14.08 1003.2 349.79 2230 3.1 16.8 0.977
    350.98 2400 95.2 0.805 29.3 350.39 2280 4.68 14.14 1003.2 350.7 2360 3.25 39.4 0.984
    351.87 2520 94.5 0.836 30 351.29 2400 4.42 14.01 1003.2 351.58 2490 3.3 64.7 0.992
    352.74 2640 94.5 0.86 30.8 352.16 2560 4.68 14.01 1003.2 352.44 2550 3.25 73.7 1
    353.62 2640 93.8 0.75 31.5 353.04 2720 4.68 14.01 1003.2 353.33 2550 3.15 98.3 1
    354.51 2160 93.8 0.945 19.5 353.9 2440 1.69 13.87 1003.2 354.21 2180 2.35 0 0.984
    355.45 2200 93.1 0.789 23.3 354.81 2160 5.72 14.01 1003.2 355.13 2180 4.15 0 0.984
    356.34 2280 93.1 0.906 23.3 355.77 2240 5.98 14.01 1003.2 356.06 2280 4.3 0 0.992
    357.25 2440 93.1 0.938 24 356.63 2360 7.67 14.08 1003.2 356.94 2400 4.5 0 0.992
    358.14 2560 93.1 0.821 24.8 357.54 2480 7.28 14.08 1003.2 357.84 2530 4.55 0 1
    359 2680 93.1 1 25.5 358.42 2600 7.02 14.08 1003.2 358.71 2550 4.4 0 1
    359.93 2800 93.1 0.805 27 359.3 2720 7.28 13.94 1003.2 359.61 2550 4.25 0 1
    360.84 2920 93.1 0.984 27.8 360.23 2800 6.63 14.08 1003.2 360.54 2550 4.3 0 1
    361.75 3040 93.1 0.789 28.5 361.13 2960 7.41 14.01 1003.2 361.44 2550 4.3 0 1
    362.67 2720 93.1 0.867 31.5 362.05 3080 6.76 13.94 1003.2 362.36 2550 2.6 0 1
    363.55 1960 93.1 0.969 15 362.96 2480 3.77 14.14 1003.2 363.24 2220 0.95 0.4 0.992
    364.44 2520 93.1 0.805 26.3 363.84 2560 2.99 14.08 1003.2 364.13 2530 3.7 1.6 0.992
    365.3 2600 93.1 1 21 364.73 2520 6.11 13.87 1003.2 365.02 2550 4.85 0 0.992
    366.21 2680 93.1 1 18.8 365.6 2640 10.66 14.01 1003.2 365.9 2550 5.4 0 1
    367.1 2800 93.1 1 20.3 366.5 2720 10.66 14.01 1003.2 366.81 2550 5.35 0 1
    368.01 2920 93.1 1 21.8 367.4 2800 10.79 14.01 1003.2 367.7 2550 5.35 0 1
    368.91 3040 93.1 1 22.5 368.31 2960 10.66 13.87 1003.2 368.6 2550 5.35 0 1
    369.81 3160 93.1 1 21.8 369.2 3080 10.92 13.87 1003.2 369.49 2550 5.45 0 1
    370.72 3240 93.1 1 25.5 370.12 3200 10.53 14.08 1003.2 370.42 2550 5.05 0 1
    371.66 3320 93.1 0.86 30.8 371.04 3240 9.23 14.08 1003.2 371.35 2550 4.4 0 1
    372.62 3360 93.1 0.75 33 371.99 3360 5.59 14.08 1003.2 372.29 2550 3.8 0 1
    373.58 3400 93.1 0.867 34.5 372.93 3400 5.2 14.08 1003.2 373.25 2550 2.9 97.9 1
    374.54 3400 93.1 0.899 34.5 373.89 3400 2.86 14.14 1003.2 374.21 2550 1.9 0 0.984
    375.52 3400 93.1 0.836 27 374.88 3440 3.25 14.14 1003.2 375.19 2550 0.8 0 0.977
    376.42 3320 93.1 1 20.3 375.81 3360 0.91 14.14 1003.2 376.12 2550 1.2 0 0.969
    377.31 3200 93.1 1 20.3 376.72 3240 0.91 14.14 1003.2 377.01 2550 0.55 0 0.969
    378.18 3040 93.1 1 20.3 377.61 3120 0.91 14.08 1003.2 377.89 2550 0.6 0 0.969
    379.06 2880 93.1 1 20.3 378.47 3000 0.91 14.01 1003.2 378.76 2550 0.6 0 0.969
    379.96 2840 92.4 1.023 14.3 379.35 2880 0.91 14.08 1003.2 379.65 2550 0.65 0 0.977
    380.89 3360 91.7 1 20.3 380.28 3320 1.17 14.14 1003.2 380.59 2550 0.55 0 0.977
    381.82 3320 91.7 1.023 30 381.19 3360 1.04 14.21 1003.2 381.49 2550 0.55 0 0.977
    382.8 4040 91 1 20.3 382.17 3840 1.95 14.14 1007.6 382.49 2550 0.45 0 0.977
    383.72 3520 91 1 20.3 383.11 3880 0.91 14.14 1007.6 383.42 2550 0.6 0 0.977
    384.61 3120 91 1 20.3 384.02 3360 0.91 14.14 1007.6 384.31 2550 0.55 0 0.977
    385.49 2680 91 1 20.3 384.9 3000 0.91 14.14 1007.6 385.18 2550 0.7 0 0.977
    386.4 2120 91 1 18.8 385.77 2480 0.91 14.14 1007.6 386.09 2330 0.8 0 0.977
    387.27 1760 91 1 11.3 386.69 2000 0.91 14.08 1007.6 386.98 1880 1 0 0.977
    388.15 1280 91 1.008 7.5 387.55 1600 0.91 14.14 1007.6 387.85 1360 1.15 0 0.984
    389 1040 91 1.016 9.8 388.43 1160 1.95 14.08 1007.6 388.71 1120 1.05 0 0.984
    389.89 840 89.6 1 9.8 389.31 960 1.95 14.14 1007.6 389.6 890 1.15 0.4 0.984
    390.78 800 88.9 0.992 9.8 390.18 840 2.21 14.01 1007.6 390.48 830 1.25 0.8 0.984
    391.66 800 88.9 0.984 9.8 391.09 800 2.21 13.94 1007.6 391.38 830 1.2 1.2 0.984
    392.54 800 88.9 0.977 9.8 391.94 800 2.21 14.08 1007.6 392.23 820 1.2 1.6 0.984
    393.45 760 88.9 0.969 9.8 392.84 800 2.08 14.08 1007.6 393.15 800 1.2 2 0.984
    394.33 760 88.9 0.969 9.8 393.74 760 2.08 14.08 1007.6 394.04 770 1.3 2.3 0.977
    395.2 760 88.9 0.961 11.3 394.62 800 2.08 14.01 1007.6 394.91 800 1.2 2.7 0.977
    396.09 760 88.9 0.961 9.8 395.49 760 2.08 14.01 1007.6 395.78 760 1.3 3.1 0.977
    396.95 720 88.9 0.953 9.8 396.39 760 2.08 14.08 1007.6 396.67 770 1.2 3.5 0.969
    397.83 1200 88.9 0.977 19.5 397.24 760 4.16 14.08 1007.6 397.54 1200 1.95 24.6 0.969
    398.7 1240 88.9 1.062 20.3 398.12 1240 3.38 14.08 1007.6 398.41 1270 1.85 16 0.969
    399.58 1280 88.9 1.047 21 399.01 1160 3.77 14.01 1007.6 399.29 1130 2.05 14 0.977
    400.47 1760 88.9 0.945 27 399.87 1400 4.29 14.08 1007.6 400.16 1590 2.45 48 0.977
    401.37 2360 88.9 0.797 30 400.77 1960 4.16 14.14 1007.6 401.06 2200 2.7 66.7 0.969
    402.25 2080 89.6 1 19.5 401.66 2520 1.43 14.08 1007.6 401.97 2380 0.45 31.6 0.953
    403.13 1360 88.9 1.031 24 402.54 1800 0.91 14.08 1007.6 402.83 1580 1.45 21.4 0.953
    404.02 1720 88.9 1 13.5 403.43 1480 8.06 14.08 1007.6 403.73 1570 4.6 0 0.969
    404.91 2120 88.9 1 17.3 404.33 1800 9.49 14.01 1007.6 404.62 2010 5 0 0.984
    405.79 2640 89.6 1 15.8 405.2 2320 10.4 14.01 1007.6 405.5 2500 5.55 0 1
    406.72 3200 88.9 1 18.8 406.1 2840 12.48 14.01 1007.6 406.41 2550 6.15 0 1
    407.7 3840 88.9 1 27.8 407.02 3440 12.35 14.01 1007.6 407.35 2550 5.8 0 1
    408.71 3760 89.6 1 20.3 408.04 3920 3.9 14.08 1007.6 408.39 2550 1.4 0 0.992
    409.63 3600 90.3 1 20.3 409.01 3720 1.3 14.14 1007.6 409.31 2550 0.65 0 0.992
    410.51 3360 90.3 1 20.3 409.93 3520 1.3 14.21 1007.6 410.23 2550 0.2 0 0.992
    411.37 2960 90.3 1 20.3 410.79 3240 1.3 14.14 1007.6 411.07 2550 0.65 0 0.992
    412.23 2520 91 1 20.3 411.65 2800 1.3 14.14 1007.6 411.94 2550 0.75 0 0.992
    413.12 2320 91 1 20.3 412.53 2400 1.3 14.08 1007.6 412.83 2380 0.85 0 0.992
    414.02 2200 91 1.008 25.5 413.43 2280 2.08 14.08 1007.6 413.74 2270 1.25 0.4 0.992
    414.91 2160 91 0.899 27.8 414.32 2200 2.21 14.14 1007.6 414.63 2200 1.15 2.3 0.992
    415.77 2000 91 1 17.3 415.2 2160 1.17 14.08 1007.6 415.48 2080 0.8 0 0.984
    416.65 1760 90.3 1 12 416.06 1960 1.17 14.08 1007.6 416.36 1860 0.95 0 0.984
    417.53 1360 91 1 3.8 416.94 1600 1.17 14.08 1007.6 417.24 1510 1.05 0 0.984
    418.42 1040 91 1.008 9.8 417.84 1240 1.82 13.94 1007.6 418.13 1180 1.05 0.4 0.984
    419.27 760 91 1 9.8 418.72 920 2.08 14.14 1007.6 418.99 840 1.25 0.4 0.992
    420.17 880 91 0.992 9.8 419.57 800 2.47 14.08 1007.6 419.87 860 1.25 0.8 0.984
    421.03 800 91 0.984 9.8 420.45 840 2.08 14.01 1007.6 420.74 820 1.2 1.2 0.984
    421.92 800 91 0.977 9.8 421.33 800 2.21 13.87 1007.6 421.63 810 1.25 1.6 0.984
    422.79 800 91 0.969 9.8 422.23 760 2.21 14.08 1007.6 422.51 790 1.25 2 0.984
    423.63 760 91 0.961 9.8 423.07 760 2.08 14.01 1007.6 423.35 800 1.2 2.3 0.984
    424.53 760 91 0.961 9.8 423.93 760 2.08 14.01 1007.6 424.23 780 1.2 2.7 0.977
    425.39 760 91 0.953 9.8 424.82 760 2.08 14.01 1007.6 425.1 770 1.25 3.1 0.977
    • pinotattt
      • Jan 2013
      • 174
      • Country: Malta
      Excel workbook
      Tried this conversion
