you need to physically check turn the car over and have some one look if the rotor is turning as once the TDC is recognised the ECU takes over at least that will eliminate that
3b timing problem
Oh well, as the rotor is obviously firing the spark plugs in the right order, I know it turns.
Here's some more pictures of what I've been up to. I'm afraid some will say "I told you so"
-Took the dizzy out to visually check it and measure resistance over the rotor.
- Resistance - 1,1 K ohm. Rotor didn't look good. Small cracks in the black part.
-Took the timing belt of, rechecked the timing, marked up all the timing marks in black marker to make it easier to see.
- Refitted the distributor on the marks.
No start.
Twisted the distributor anti-clockwise about 3mm, fired right up.
I stopped and started it a few times, everything was allright.
I waited for the temp gauge to reach 90°C, then switched off.
After that, it wouldn't start again.
I'm thinking, either the front crank sprocket has come "loose", or the hall sensor is on it's way out. A friend is bringing a locking tool over next weekend, so will be able to check that. The search for a new distributor is on!
Edit: Pics tomm, f**ked it up.If at first you don't succeed, destroy all evidence that you tried.
-CQ 3b "S2".Comment
I had a similar issue with my 3b, turned out I had lined the fly wheel on the mark. I had mine lined up with the line on the fly wheel and not the line with the zero. Gave myself a few doh 's for that one.Comment
1. Get an improved sprocket while you're at it from this forum, see for sale section.
2. I believe you can replace the hall sensor, or was that only on ABY/AAN/ADU?Comment
I can't see that line anymore.
Using the line with the "0".
-CQ 3b "S2".Comment
You can't rely on the lower front pulley marks, they can be way out. On the 3B you must use the zero mark in the bellhousing window and you must roll forward onto it to take up any backlash in the cam belt and dizzy drive.Comment
Yes, thats what I've done this time around. Didn't take up the slack in the dizzy, but it did start.
I'm at a loss for why it wouldn't start again though.If at first you don't succeed, destroy all evidence that you tried.
-CQ 3b "S2".Comment
Went out to do something with one of the other cars today, but i brought the keys for this one. It fired right up :-/If at first you don't succeed, destroy all evidence that you tried.
-CQ 3b "S2".Comment
It looks like you don't have the narrow 3B rotor too? Not that would prevent it from starting that is down to the timing marks, but it would be wise to get one or file the current one own to size.
It's probably worth noting that pics of the timing marks linked on the first page show the flywheel mark on 200 20v with the 016 transmission which lines up a little different in the window on the bellhousing than the 01A in the S2.
Austin
1992 urs4 1991 200 20v avant 1990 90q 20vComment
You could be right on the rotor, although i measured it to 11mm. Is the narrow one even narrower?It looks like you don't have the narrow 3B rotor too? Not that would prevent it from starting that is down to the timing marks, but it would be wise to get one or file the current one own to size.
http://s2central.net/temp/timingbelt2.jpg
When mine was lined up, it was with the line aligned with the straight piece in the bellhousing, and I could see half the "0".If at first you don't succeed, destroy all evidence that you tried.
-CQ 3b "S2".Comment
Should probably change the topic text, as the timing doesn't sem to be the culprit. It starts when cold, but not when warm.If at first you don't succeed, destroy all evidence that you tried.
-CQ 3b "S2".Comment
Is the hall sensor clean? Does the dizzy have a metal gear?Comment
-CQ 3b "S2".Comment
