rs2 timing belt
  • rxl
    replied
    And the shipping is like 15euro?
  • huksa
    replied
    Originally posted by rxl
    58,91 Euro plus postage.
    EUR 49.50 for those who live outside Europe
  • rxl
    replied
    Originally posted by huksa
    As of Sep. 12, 2014, the RS2 timing belt 034109119C is available at Audi Tradition.
  • diesel des
    replied
    I wonder what the cost is?
    Sent from my GT-N7105 using Tapatalk
  • huksa
    replied
  • diesel des
    replied
    Ok started...
  • rxl
    replied
    Originally posted by diesel des
    I haven't started a thread yet but I have taken many pictures. Hopefully will be running in the next few weeks. I'm going for torque and low to mid range power, not big bhp. I'm going to try a efr 6758.
    Make one... Want to see some custom work.. Have seen some for a time
  • diesel des
    replied
  • rxl
    replied
    Well I know that the belt is the wrong one. But it was on the car and worked. Do you have some pictures or a thread on your stroker project?
  • diesel des
    replied
    Rxl that isn't the correct belt for a rs2. It has 151 teeth and the correct belt has 150. Obviously it will work but your Tensioner must be almost fully tight.
    My problem is that I have a stroker engine with 3b s2 oil and water pumps so my weird setup needs something shorter than the 151 tooth belt or a larger idler.
    Cheers des
  • rxl
    replied
    Anyway the belt on my rs2 with 26 tothed water pump
  • diesel des
    replied
    After some testing I reckon increasing the od of the 3b oil pump idler I'm using from 74.8mm to 81 will get the tension I want with the water pump 2/3 of the way along its adjustment. So I'm getting a steel sleeve made up 75mm I'd 81mm od 28mm wide and pressing it onto the idler with bearing fit compound and tacking it on there in a few places.
  • diesel des
    replied
    Andy, how soon is soon? I was thinking of modifying the idler so it is bigger and would allow me to use the 151 tooth belt. I want to put the engine in next weekend....
  • AndyRS2
    replied
    I spoke to Audi Tradition, the RS2 Cambelt with 150 teeths, will be for sale soon.
  • diesel des
    replied
    Guys do any of the aftermarket companies make a proper rs2 belt eg 19 mm wide 150 teeth 034 109 119 C? Or has anyone talked to a drive belt company to get these made. Seem to have 8mm pitch. I need a proper adu rs2 150 tooth belt for my stroker build. I couldn't find these on audi tradition. Help! Cheers des
