nahh problem revisited.i just had a chance to be high speed cruising.hit 240km/h,boost 1,8bar.back home and checked the oil separator.i see a
fair amount approx 10-20cc of oil in the separator.what's next? damn!Do i need to remove the small check valve under the intake manifold.the stock
one doesn't seem to be 100% sealed.All of the stock check valves did that.is it possible that the boost pushed out the motor oil in the sump?
