Any merit in putting a fan on a oem urS6 Intercooler ?
    Just wondering if it would be any use to put a fan on the oem intercooler of a urS6 as ghetto solution for increased performance, rather than the expense and hassle of fitting a FMIC ?
    Currently car is standard, but looking a RS2+ type spec in the long run.
    Any comments ?
    • 4754
    Good idea probably?? ...can we have pictures of the car??? We all like pictures.Any chance? Cheers.
    • Rusty
      • 18953
      Won't make a difference when you're moving along though, so not really worth it.
      Water injection and an intercooler spray will though.
      • A1QSHIP
        • Aug 2004
        • 975
        Cannot hurt to have a small fan on whilst driving in traffic. The real issue is to make the air have some place to go AFTER it goes thru the intercooler. I started with house foundation ventilation screens & cut them down to fit in the wheelhouse liners. This gave the added benefit of getting some more air thru the oil cooler on the other side & cooler air to the brakes. It is a tight fit & with larger wheels & tires there was a bit of rubbing to be sorted.
        Chris
        "Nulla tenaci invia est via"
        • andy10v
          • 5996
          It should help reduce heat soak when stationary.
          Sold ABY-stock
          • pasbogdan
            • Sep 2009
            • 1160
            • Country: Romania
            On stock k24 7000 with moderate boost IAT is not a problem.At hp limit of the k247000 the compressor itself is a problem,so cooling down 0.2 bar extra does not worth.Get further with the turbo.
            • Wrath
              • Jan 2011
              • 779
              Install wheel arch ventilation from a newer S4.
              Look at Thuppus thread... First 10 pages or so...
              1995 Audi S6 - AAN (~350hp)
              2008 BMW 530xd (235hp)
