Can anybody advise is this injector physically the same as the RS2 injector.
Bosch EV6 440cc Injector
Part number 0280155968
Specifications:
Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 42 lb/hr = 440cc/min
Connector: Bosch style connector EV1
Orifice Type: Multi-orifice
Spray Pattern: 30 Degree Spray Cone
Factory fitted with Viton upper and lower o-rings
Length 65mm (60mm O-Ring to O-Ring)
Thanks
orsum
Specifications:
Thanks
orsum
