What MAF hose are you running, is it the original one and is it old and soft? It's possible for the turbo to collapse the MAF hose at high RPMs and boost, that will stall the turbo.
Otherwise you need to make sure the DV is opening when the throttle closes and the N75 is connected correctly and there are no boost leaks anywhere in any of the small pipes.
If the DV doesn't open you get a lot of fluttering sound through the airbox..
