As title. I'm almost finished the stroker build and I need to fit a 3b style belt cover. I have the 3b oil and water pumps and have lengtheneda the 3b cover and backplate. So need some pictures and part numbers of the bolts that go through the cover. Are clips used round the edges too? Anyone got some? Cheers des
What holds on a 3b timingbelt cover
Tags: None
Not sure where now but you can get stainless ones of those tube nuts, I was thinking the other day I need some for mine.Comment
Good stuff. I need 11, 12, 13 and 14 in that diagram. You don't happen to have the part number for those? Stainless ones would be nice!Comment
From vagcat, might be worth confirming in etka?
Do you have No.10, the stud in the block?
10 N 10074603
stud
M6X35 /
11 034109135
spacer tube
A38X52X7 /
12 034109135A
tube
13 049109207
shouldered nut with socket
M6 /
14 056129669BCurrent-2004 Impreza PPP wagon
Sold ABY-stockComment
Best buy them quick as custom autocraft is apparently closing down;
Group buy??
don't buy them all, I'm ordering some as well.
