Last dyno session my car made 515whp @ 2.1 bar and E85. I have a other dyno session planned at the end of this month to do some tweaks and to see how the car is performing now.
As discussed here :http://www.s2forum.com/forum/showthr...t=70119&page=2 my 7a cams are 0.5 tooth out when my engine is at TDC. I did not had time at the last dyno session to look at this.
Now i like to try and see if i can make more power by adjusting the cam timing on the cam pulley. But what is the best way to do this? Just set the cam wheel at the original timing mark on the cam cover and than just try whats the best setting? Or is there a better way?
0-200km/h 9sec
You started with both cams about 8 degrees advanced. How was spool compered with timing then and now?
