Meyle MFTS fault
    Meyle MFTS fault
    OK we all know the Meyle MFTS units read a bit high on the temp gauge, but I have another fault with mine (brand new but bought a couple years ago so can't even return it)
    It sets off the autocheck over temp alarm continuously. Anyone else had this?
    Looks like I need to buy another one, will get a Behr this time, another £50
    Should have spent the £100 for a dealer item first time round
    MEYLE MFTS is a P.O.S. !
  • Mikes2
    • 1704
    I found the Behr one wasn't trouble free either.
    Fine at idle or town driving but would drop to ~60 degrees at motorway speeds.
    I'm currently running a JP Group sender, part number 919064001 which has been perfect.
    Got it from Ebay Germany for <20 Euros
    Mike
    http://www.s2-audi.co.uk
    • popdemonic
      • Dec 2007
      • 1304
      • Country: Thailand
      not sure if the Behr sensor is made in China on this day but i have it on my car and been working flawlessly.
      one of a few I5 from Asia.
        Thanks Mike. I've ordered one of those JP units, fingers crossed it does the job as yours is
        • quattrostyle
          • Oct 2006
          • 6229
          Meyle electrical parts are quite bad. I had a problem with a brand new temp. sender on my coupe type 85.
            The flashing overtemp alarm can sometimes be cured with a sharp blow with a socket extension bar or similar blunt object.
              Haha, yeah I tried that already. I call it a "rage tickle"
              • andy10v
                • 5996
                Yup, I had a brand new one, water gauge was perfect, set off autocheck and killed boost as soon as it hit operating temperature.
                Sold ABY-stock
                  C*&t! Don't they ****ing test this stuff? The new Meyle expansion tank I have is ***** too, its has swollen up like a tomato now its been head cycled a few times, wouldn't be surprised if it cracks soon, so I'm going to have to shell out for a new OEM one, if you can still get them.
                  My opinion of Meyle has dropped a long way in my estimation this week.
                  • andy10v
                    • 5996
                    I ended up driving about for ages with the MFTS unplugged just so the car would boost, need faith in the cooling system for that tough!
                    Maybe I will just stick with my scabby old expansion tank, it might look like **** but it works!
                    Sold ABY-stock
                      Oh yeah forgot I sold you that spare 3B one! Looks like me and Meyle ****ed you in the *** too
                      As with most parts though, the 3B item is probably better quality so maybe it will be ok.
                      • quattrostyle
                        • Oct 2006
                        • 6229
                        Although you bought the items long ago it might still be worth it to contact Meyle directly? Not that I did that with my new failing sensor
                        The expansion tank on my cabriolet looked new but was swollen as well, wonder if that would have been a Meyle then...
                        • Monkeymagic
                          • Mar 2012
                          • 3419
                          I bought a new Febi Header tank, no complaints at all very good quality. Also I got the MFTS from Pete and Quattro corner for £45 and its a Behr one. My previous Behr one had started setting the Auto Check off on occasion but it had been on some time looking at it.
                          • CoupeWannabeS2
                            • 403
                            Is this the MFTS that MikeS2 and Error404 are talking about?
                            http://www.ebay.co.uk/itm/Thermoscha...item5b07925845
                              Yes that looks like it
