the reason for the BB turbo won't last long due to the inner cage of the bearing couldn't withstand the abusive.
it made of something like the carbon or elses.you need to upgrade the cage to the steel.my GT2871 is last or 7yrs
around 100,000kms.if you searched on the youtube you'll be found a lot of BB turbo having bearing noise after
shut down the engine.i did have the same thing.recently i rebuilt my GT turbo with the new bearing kits and piston rings.
but it seems the BB turbo ain't easy to rebuild it right.it required a lot of special tools to pull it apart,VSR balanced machine.
the clearance on every parts must be precisely.i ended up sending it forth and back to the shop for a couple times.
that's PITA. my bearings on the turbine is worn as well.
Dmitri's result is just the highest dyno graph I have seen with the 35S. Would need a little bit higher level to gain 100hp with e85.
