turbochargers for 500hp
This topic is closed.
  • nicksonmsport
    • Mar 2014
    • 380
    or how about this turbo ??
    http://www.ebay.co.uk/itm/NEW-HOLSET...item3ce9a27ebf
    looks like it gives good results on similar sized engines and not to laggy!
    • Thuppu
      • 4115
      Here you can order a "Super" with #8 single entry hot side. http://www.kkdmotorsport.com/product..._id=1276068696
      • Jaswan
        • Apr 2011
        • 766
        i have a precision 6262 CEA ball bearing turbo for the engine that is going into my coupe. i am looking to make 500 WHP initially.
        • quattro-nick
          • Sep 2012
          • 1746
          • Country: Belgium
          the gt3082r is a 600hp turbo.with 0.82 ar i think full boost at 4200 rpm but i'm not sure
          TWINCHARGED power,zero lag
          AEM W/M injection
          • A80Avant
            • 10873
            • Country: Greece
            #20
            The gt3082 is an older turbo I think. The gt35 is the one that makes up to 600 hp. The 3082 must be a mixture of gt30 and hot side of the gt35. May not even be ball bearing.
            • bartolomeus
              • Jan 2009
              • 1475
              • Country: Romania
              #21
              I think we should make a pol with the best turbo for 500-600 hp range
              • FCP-ENGINEERING
                • Feb 2011
                • 173
                • Country: Lithuania
                #22
                HX35 with billet compressor wheel and 8cc hot side 630eur including shipping.
                Audi S4 2.6 20V STROKER kkk26/27
                • bartolomeus
                  • Jan 2009
                  • 1475
                  • Country: Romania
                  #23
                  http://www.ebay.de/itm/Audi-S2-RS2-S...item3ce99191b2
                  • PRY4SNO
                    • 767
                    If you want to make good boost in the 3k rpm range and make 500hp you can't afford a cheap turbo.
                    EFR7670 or EFR7163 or HTA3076 (but it won't spool as fast, have as good transient response between shifts or make as much power in the top end).
                    2013 Touareg TDI /// #farmenwagen
                    • snp10
                      • Nov 2012
                      • 189
                      • Country: Romania
                      #25
                      Garrett Gtx3076 or Holset Hx35 super for 500 Hp + ?
                      • nicksonmsport
                        • Mar 2014
                        • 380
                        Im thinking gtx3076r is the safe option to achieve what im after!
                        Anywhere in thr region of 500bhp and good spool and im happy. Car should only weigh max 1000kg so peak power output is not a massive issue
                        • Albert
                          • 1500
                          • Country: Poland
                          #27
                          GTX3071R with A/R 0.82 should do it
                          AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
                            Not a fan of BB turbos after reading about plenty of problems with them over the years (not run one myself) - if reliability isn't a concern then you're laughing or just run multiple filters before the pressure restrictor. I'd go journal bearing and accept a little more lag for some improved reliability. That said, I found that the Holset was oil cooled only, so I'd want to address that...
                            Perhaps a billet wheel on a Holset is along the right lines...
                            • Jaswan
                              • Apr 2011
                              • 766
                              #29
                              a friend runs a GT3076r on his RB25DET and it makes 520 bhp (crank) and he says thats it pretty much maxed out.
                              i dint know any one with a GTX version
                              • A80Avant
                                • 10873
                                • Country: Greece
                                #30
                                BB turbos are fine. All turbos are fine so long as you run them in spec and as meant to. The majority of the world runs BB turbos and I wouldn't take a step back going to journal bearing just because a few loud voices said they had a problem with a BB turbo. So long as it's a reputable company it's fine.
