turbochargers for 500hp
This topic is closed.
  • Albert
    • 1500
    • Country: Poland
    #91
    Gtx3076r shuld get you over 600hp+ mark
    AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
    • diesel des
      • 3896
      #92
      Gt30 turbine doesn't like to flow 600bhp. At 500bhp it is happier.
      Sent from my GT-N7105 using Tapatalk
      • snp10
        • Nov 2012
        • 189
        • Country: Romania
        #93
        I saw live Dyno for 2.2 20 v with normal Gt3076 (Not a gtx) . At 2 bar pressure made 520 hp. I am thinking that GTx3076 can deliver 600 hp according to engine specs.
        • Albert
          • 1500
          • Country: Poland
          #94
          Whith GT3071R and 1.5 bar I had 450HP. GTX3076r + 2 bar will get you no problem to 600 HP. All on VPower fuel
          • Albert
            • 1500
            • Country: Poland
            #95
            GT3076R is exacly 525 HP turbo ...
            GTX3076R is 600HP + one. You need to have proper cams and head work done.
            • prj
              • Mar 2010
              • 6308
              Wishful thinking, the GT30 turbine maxes out at around 500hp.
              Sticking a bigger comp wheel on that is a waste of time, which is why in independent tests a GTX3076R only delivers 5% power improvement, if even that. The GTX turbo to have with a GT30 turbine is the GTX3071R, as it is basically a GT3076R with better spool.
              Easy to get lost in compressor maps, but there are always two halves to a turbocharger, and both have to flow. There is no sense in using a huge comp wheel when the turbine is choking.
              A GTX3582 or GTX3576 are much better ideas.
              • nicksonmsport
                • Mar 2014
                • 380
                Prj as a master mapper, what are your thoughts on the holset turbos?
                I have been offered used gt3082r and gt3582r, any thoughts on these options?
                500bhp, decent repsonse and full boost/torque by 4000-4500rpm max.
                • Quattronaut
                  • May 2013
                  • 273
                  ´Til now, I thought the improvement from GT to GTX was on the one hand the better geometrie, on the other hand the possible higher revs of the GTX series due to better materials.
                  Prj, your post says, that there is nearly no difference in the capacity of the turbines-with higher rpms possible, choke line of turbine should be improved, too, so is the rpm level or limit the same between GT and GTX? Was the turbine side changed? What is the improvement from GT to GTX?
                  • A80Avant
                    • 10873
                    • Country: Greece
                    #99
                    Only the compressor wheels have changed. The turbine wheels are the same.
                    • diesel des
                      • 3896
                      #100
                      The physical turbine choke limit will be higher if the compressor is turning faster. Compare the gtx3076r and gt3076r compressor map speed lines. Don't think it can spin much faster....
                      • BosnianS2
                        • Apr 2005
                        • 322
                        • Home: Bosnia and Herzegovina Current: Germany
                        #101
                        Originally posted by nicksonmsport
                        I cant find much information on the ''super''
                        also twin scroll so will need a funky manifold to work properly
                        you mean this one?
                        http://www.ebay.de/itm/Abgaskrummer-...item19f4257e51
                        • prj
                          • Mar 2010
                          • 6308
                          520hp - HX35 Super and WMI kit. Full boost 3800 rpm. GT3082 is pointless, like GTX3076. GT3076R is OK, but full boost will be 4200 rpm, 400 rpm later.
                          The HX35S is closer to the GT3071R in spoolup, but flows almost like the GT3076R.
                          It is at the moment THE turbo for a streetable 2.2T.
                          KKD motorsport on suomalainen verkkokauppa ja kivijalkamyymälä Kuopiossa. Verkkokaupasta löydät laadukkaat viritysosat ja tarvikkeet. Suuri varasto takaa nopean toimituksen. Tutustu valikoimaan ja tilaa helposti verkosta!
                          All the Holset lag stories are due to people using incorrect hotsides for Gasoline applications - which is understandable, as these are originally Diesel turbos and Diesel turbos have much bigger hotsides, as the exhaust volume flow on Diesel is higher.
                          As for twinscroll - on a 5 cylinder engine this is not going to happen.
                          • nicksonmsport
                            • Mar 2014
                            • 380
                            ok thanks, the main thing here is this is not a street car at all, it is a track only/race car. the only thing holding it back at the minute would be rev limit of around 7500rpm, so im just after a turbo that gives over 500bhp and a decent powerband that doesn't need a high rev limit due to the turbo coming on boost late and giving max power at 8k rpm+
                            thanks
                            • prj
                              • Mar 2010
                              • 6308
                              Maybe I did not put it the right way. 500hp is the limit on a 2.2T that is drivable.
                              Everything more you have so much lag that the car is only good going in a straight line with an antilag start.
                              Either that, or you need very deep pockets to create a well usable power band.
                              • Sonic
                                • Jul 2006
                                • 5514
                                #105
                                Indeed i find this about as good as you can probably get for street driving... 464bhp (without wmi) / 650Nm torque causing all hell-for-leather before 4500rpm. If you're in any doubt ask the chaps in the 550bhp c63 AMG, 997 GT3 RS and tuned Nissan GTR that were following me around Wales
                                S2Forum.com Administrator
