Which thermostat?
    Thats pretty much what mine is doing. It will get to ~90° at a standstill, taking a bit longer than usual. Once on the move the temp drops quickly to ~60°. Using quite a bit of fuel as a result.
      Are you going by the gauge or ECU via vagcom? as that sounds like a temp sender fault, I had that at one point, the ECU reads from a different sensor IIRC Now S2central.net is back you can ask him.
        I checked with measuring blocks in VAGcom and ECU was reading similar (from the sensor on the back of the head)
          Thats good to know then that it's not a temp sensor issue, the only other thing is the clocking of the stat, but they have been known to fail especially the gsf aftermarket ones
          • Bowie69
            • Nov 2013
            • 2675
            Cheers Alex, it's the same part no for a 7A as well, just confirmed in parts cat
            • Human Joist
              • Nov 2012
              • 189
              Sorry. Mistyped the entry as phone playing up. The mfts was £50 half price. From memory the thermostat was around the £12 mark from QC
              • AndyP
                • 6049
                I've had nothing but problems with non-genuine ones ( GSF and ECP supplied ) so I always splash out and get a Wahler from the dealer, not cheap at almost £20 but never had a problem.
                Any idea what difference clocking them makes as I never knew about this before??
                • Bowie69
                  • Nov 2013
                  • 2675
                  Without looking it is likely to be a bleed hole to allow air or steam to pass through and stop air locks forming as the thermostat sees a lower temperature.
                  Also aids filling.
                  But there may not be a hole
                    There is a small hole
                    I think it also helps the coolant to circulate around the block & head preventing hotspots
                    • johne
                      • Apr 2007
                      • 1405
                      You don't want a thermostat with a small hole in it like the Frusser ones from GSF because if there's even a small hole your temperature will fall away cruising on the motorway in the winter.
                      Small hole with a jiggle pin to close it like some Wahlers is fine.
                      John
                      • JariP
                        • 192
                        I had this same problem with temp gauge readings, changed the thermostat (Wahler) and still the gauge reads low as before. I recommend checking the temperatures with a laser temp gauge or thermocouple before changing the thermostat. Water hose going from head to heater matrix might be a good place to start measuring the temps.
                        • DNA-S2
                          • Sep 2012
                          • 369
                          I will be trying out some that they open at 71C on my current builds
                          Like the idea of water/coolant exchange earlier
                          Danny
                          www.dnaautocare.co.uk
                          • AndyP
                            • 6049
                            I know that if there is a hole you put it at 12 o clock, but I'm 99% certain that the Wahler ones don't have a hole
                              How did you resolve the issue Jari?
                              • Thuppu
                                • 4115
                                I did resolve a similar problem(low gauge reading) with a new multi-sensor.
