Which thermostat?
  • Bowie69
    • Nov 2013
    • 2675
    My cheapie thermostat has done this since new as well......so I wouldn't say it isn't faulty, it came faulty from the box!
    I have a new OEM one coming from Quattro Corner, along with a pair of front wheel bearings, Pete is a nice chap
    • Michael S2
      • Dec 2011
      • 1378
      Alex - did you solve the low temp reading while cruising?
      1995 Audi S2 Avant
      • Bowie69
        • Nov 2013
        • 2675
        Well my thermostat, a Mahle one, despite looking a hundred times better than the last one, has started running cool again! Just over what I think is the 80C mark
        Anyone got any good tips for catching coolant as it gushes out the thermostat hole -I'm getting fed up of forking out for new G13 each time I open it up!
        • andy10v
          • 5996
          Put a bucker under the radiator, undo the lower radiator hose, point the hose down into the bucket, if you have positioned the bucket correctly the radiator will also drain into it.
          Sold ABY-stock
          • Bowie69
            • Nov 2013
            • 2675
            That's all good, and done, but when you pop the thermostat it only then empties the block, and quickly, and everywhere.
            • andy10v
              • 5996
              Bigger bucket?
              Tesco do a big rectangular storage box you can fit a cylinder head in, that would be a good catch bucket.
              Sold ABY-stock
              • Bowie69
                • Nov 2013
                • 2675
                Bigger bucket = taller = need to jack the thing up to get it under, but yes, I will get creative this time I think
                  Yes mine heats up quickly now. Still displays under 90 when on higher speed cruise 60mph+ but I think that is due to the airflow over the sensor as temp pops back to 90 within 15 seconds of slowing down to town speeds. I don't run aux rad or the rad duct on the block side
                  • andy10v
                    • 5996
                    This kind, 32L .£4.50
                    Sold ABY-stock
                      That is for storing horse burgers I believe
                      • CoupeWannabeS2
                        • 403
                        Originally posted by Error404
                        Lol, £50 delivered Hope they're gold plated.
                        Just ordered a genuine Wahler from Amazon for £15 delivered.
                        For reference Wahler p/n is 4116.87D1
                        Cheers folks
                        Thanks for posting the part number - I have just ordered one of these from Amazon.
                        • V6quattro
                          • Sep 2008
                          • 949
                          My Whaler failed after around 25000km. Car didn't get up to temp. Anyone else had this problem? I now fitted one i had lying around from my A8
                          1360kg/600Whp Avant 0-200km/h 9sec
