My 3b rs2 coupe has developed running issues, mostly of boost. At times on tick over it
Starts to run lumpy like its on 2 or 3 cylinders. other times it is fine. it does it when its started from cold, not straight away, but after its been running for a while, so not head gasket issues. Other times when its hot. In gear it will start to run like it running out of petrol. I put my foot down and get nothing for a second or two and then it launches forward on full acceleration, its a bit scary driving in traffic I can tell you.
I do not have vagcome, and for some reason I cannot blink the codes on this car. So
today I changed the maf for a known good one, and checked the maf blug, all the pins seemed fine. Changed the isv for a known good one.
Did a full boost leak test including blocking the hose to the wastegate. No leaks.
It boosts a bit lower than normal, about 1.5 instead of 1.9 with the odd miss on wot .
But most of the problems appear under 3000 revs. Plus as I say it is intermittent
Lamda was changed a couple of months ago.
If anyone has any ideas, I would be very grateful for some advise
