Is an oil temp of 90 and pressure at 4.5 ok?
  • Jonas_R
    • 3781
    • Country: Denmark
    Cant seem to find out what is right and what is not right.
    Running 3b ~ 310 hk with castrol rs 10w-60
    When idle and warm i have 2-2.4 bar pressure and temperature is around the second mark se picture.
    When driving at 4000 rpm oil pressure is between 4-5 bar, newer over 5 bar. Oil temperature is sometimes as the red arrow or perhaps between yellow and red arrow.
    Is this oki or should i be looking at changing the oil cooler?
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • S2sedan
    • Aug 2004
    • 189
    Mine is in the same temp... but I always see more than 4 bar over 3000 RPM. On normal driving I never saw oil temp over it, only in track days and at highways revving up.
    S2 Limo sold !!!
    M5 E34 with some mods in the garage
    sorry, but much happeir now !
    • NoNonsense
      Forum Sponsor
      • Apr 2004
      • 673
      that's fine...oil won't start to break down until after that red arrow. A larger oil cooler on a modified turbo car is never a bad idea, but you are ok at that range.
      Joe "NoNonsense"
      axis motorsport
      joe@axismotorsport.com
      • Fat Audi 80
        • 10547
        Sounds normal, I had seen mine over the red mark in the summer when driving enthusiastically..... I would have thought oil in the engine is going to be at least 90 deg C anyway as that is the temperature of the coolant give or take 5 degs.....
        Cheers.
        Steve.
        The Perfectionist
        • Lee
          • 1512
          MIne regularly goes over 120C on a thrash or a trackday. My chosen 10W60 oil is good for 125C continuous and 150C intermittent...thats why I use it!
          I see 2 bar at idle when hot and no less than a full 5 bar at anything over a few thousand revs. I have a high mileage car (160k+ miles) but still seems healthy enough.
          Jonas, those images look ok and what you discribe is ok at idle too.
          Designun Limited....
          • Jonas_R
            • 3781
            • Country: Denmark
            Well mine hits between 4-5 bar when yours hit full 5 bar, but is oki as long as it is over 4 bar in pressure? I mean there are only to "dots / notch" between 4 and 5 bar on the gauge.
            /Jonas R.
            • sorens2
              • 241
              • Country: Denmark
              That´s fine Jonas. Mine is the same.
              You should get a ride with me some day, then you buy a bigger Garrett..... :-)
              Søren S2
              Audi RS4 LO550
              BTG 8:08
              www.fredslunds.dk
              • Jonas_R
                • 3781
                • Country: Denmark
                Søren S2
                Hehe that would be nice, tried Torben (Audi-Sports) S2 with the antilag system, that was pretty crazy.
                So would not mind trying a S2 with even more powet.
                Why dont you come buy in the summer when Audi Club Dk ís holding a gathering in Judland.
                /Jonas R.
                • sorens2
                  • 241
                  • Country: Denmark
                  Will do, if I´m home.
                  Have I got more power than Torbens....?
                  I´ve got flatshift as well.
                  Søren S2
                  Audi RS4 LO550
                  BTG 8:08
                  www.fredslunds.dk
                  • Jonas_R
                    • 3781
                    • Country: Denmark
                    Yeah iam pretty sure you have more power then Torben.
                    Har du ikke noget over 400 hk?
                    /Jonas R.
                    • sorens2
                      • 241
                      • Country: Denmark
                      That´s true.
                      Somewhere over 400 hp
                      Se you at the sommermeetings.
                      Søren S2
                      Audi RS4 LO550
                      BTG 8:08
                      www.fredslunds.dk
                      • NoNonsense
                        Forum Sponsor
                        • Apr 2004
                        • 673
                        that's like new...you still need to break in the engine!
                        Joe "NoNonsense"
                        axis motorsport
