What I heard there is that you want to adapt the covers to work and let air out lol... and also that you need to find a more suitabler job to accomodate this again
Working as a CAD monkey for a contractor is a bit different to working in a place that machines metal as part of their business
I want to improve the covers aesthetically and also remove dead weight and restrictions to airflow, as well as improving cable routing and maybe even sort the breather out too...
Not much then.
Here's a mock up with 20mm spacers. I will look at removing material from the coil cover and cleaning it and the rocker cover up and giving them a lick of paint. This will improve air flow and I think it looks perfectly acceptable.
