Timeing Belt Condition
  • bilko0795
    • Feb 2011
    • 1883
    Just done the timeing belt and on starting the car the belt as slipped back and touched the cam cover and there are is some showing of the thread on the belt in places.
    My question is will the belt still be ok to use or do I buy another one I know what I think I should do but would like some feedback from other members first.
    I would get a new one, not worth the risk for a £20 part.
    Why did it walk to the back of the pulley though? Did you forget the diamond washer on the crank nose?
    • bilko0795
      • Feb 2011
      • 1883
      Alex , how did you guess I fitted a billet crank sprocket and because the fit wasn't as snug as the one I took off. the billet one pushed on was flush with the end of the crank and when I pulled it forward a touch to fit the washer and the pulley it was loose on the crank as the Oem one when pushed on left enough room for the washer and when pulled forward a touch for the pulley wasn't as loose as the billet one and having read on here ref some Oem sprockets breaking I went with the billet one and left the washer off I could of left the Oem one on as I have the garage bill from the last guy that had the car and it was changed then and the car has only covered 20 thousand miles in the last 6 yrs and it looks fine no hairline cracks around the bolt holes. Oh and the belt is £32.66 + vat from Tps.
      • Michael S2
        • Dec 2011
        • 1378
        Still change it for the sake of £39.19
        1995 Audi S2 Avant
        • John.
          • 2615
          £17.50 plus the "vodka and tonic" for a Gates belt for my 7A.....same belt I think?
          Where was the billet sprocket from..... 034?
          John.
          • AndyP
            • 6049
            http://www.ebay.co.uk/itm/GATES-POWE...item2a1eebf1fb
            Gates makes Audis cambelts so this is the same belt, you just don't get 'Audi' on it
            • ManiacuV6
              • Dec 2009
              • 458
              • Country: Romania
              Following that link and finding that fits also Nissan 200 S13 i found this http://www.ebay.co.uk/itm/GATES-RACI...item23431a3ffa
              So I think that high strenght belt can be fitted to 2.2T 20V engines .IS it right?
              I hope that I didn;t hijacked your topic.
              Audi S4 2.2T 5 spd 1992 for parts
              AUDI A4 1.9TDI daily use
              Audi 80 Quattro 2.0 16V (ACE) aka Competition
              • bilko0795
                • Feb 2011
                • 1883
                John.
                No i got it from volcano Rs on here.
