I'm off on Sunday on a 2,600 mile rally around the French Alps. I have got the car running again after many years. I was told by the rolling road technician the car was running lean. It was suggested by a friend that the 12volts may be missing from the lambda sensor. I've not had time to check yet. The car was bought as a damaged repairable 21 years ago and so I don't know if anything is missing.
The panel in front of the drives knee shows the relay in position 12 to be for Lambda sensor. no relay is present.
Should one be there?
what is the number please?
I have attached a photo, the holder referred to has a purple identification band.
