😳 erm..
I'm all
The fuel relay has also been advised to me, I'll get on the case a week Saturday when I see the car again 👍🍻
I also have a noise that sounds like a distant foghorn when I come off the throttle, even light throttle, sounds like a valve resonating air somewhere
When the turbo blew up on s previous time I owned the car... it ruptured both crankcase seals which where replaced.
How can I pressure test the crankcase to check that no pressure / vacuum is leaking ?
I'm all
Pull the vac line off the front of the IM and suck on it, you should have vacuum.
