Hello all, almost got the colgate wagon working perfectly as before, some of you know I have recently had some misfire issues but have upgraded to 1.8t coils.
Oddly it seems to be hesitant in the lower gears 1-3 when revving high, if I use 4-6 from low revs and hit the loud peddle it pulls like a train cleanly all the way to the red line.
So 1-3 over 4k and it feels like its bogging down but if I hold the power long enough I can still drive through it all the way to 1.7 bar.
Normal driving is spot on and so is idle when warm, when cold first thing it splutters slightly but after a blip of throttle it sorts itself out.
Spec is:
RS2 Turbo
RS2 exh manifold
RS2 injectors
RS2 airbox
RS2 intercooler
044 fuel pump
T+S tuning chips
R201 resistor mod
1.8t coil pack conversion
new lambda
Silicone hoses and vacuum pipes
No fault codes or boost leaks, any ideas gents?
Spec is:
RS2 Turbo
RS2 exh manifold
RS2 injectors
RS2 airbox
RS2 intercooler
044 fuel pump
T+S tuning chips
R201 resistor mod
new lambda
got them cleaned and rebuilt and it was like driving a new car again. Might also be a slightly sticky FPR not acting quickly enough or even the fuel pump!
