Found On Roadside Dead
  • bernsaudi
    • Feb 2007
    • 592
    Heading home yesterday after a 80 mile drive in the middle of nowhere s2 drops power, I suspected fuel so pulled over then and there. Petrol station was 100 yards so got a gallon and put it in.
    No start, got towed into a mate of mine.
    Pulled 00515 camshaft position sensor g40 short to positive.
    I swapped my ecu for another to verify, after that swapping the cps for another second hand one I got
    00515 camshaft position sensor short to earth.
    So far i havent got even a cracle out of it since it went funny, it didnt tow start either.
    Any ideas?
  • Tonks4x4
    • Nov 2005
    • 3062
    Strangely, I would start by replacing the camshaft position sensor...
    Audi Nut!!!
    • driftin jo
      • Sep 2007
      • 2222
      Have you tried messing with the connector to the cam sensor ?
      It's not going to start without the G40 input as the ECU does not no
      what stroke the engine is on, it will not open the injectors until it gets correct G40 signal.
      • bernsaudi
        • Feb 2007
        • 592
        any suggestion on a good company to get one from?
        • prj
          • Mar 2010
          • 6308
          Don't try to start it!
          Check the timing marks before you bend your valves, most likely belt slipped a tooth if two sensors with different codes!
          • rj scotty
            • May 2006
            • 2195
            a very good point well made
            BUT I DON'T WANT A NEW CAR!
            1995 S2 Avant, Volcano Black
            • bernsaudi
              • Feb 2007
              • 592
              What would be causing two sensors to throw different codes?
              • A1QSHIP
                • Aug 2004
                • 975
                Reiterating the above.
                "Nulla tenaci invia est via"
                • bernsaudi
                  • Feb 2007
                  • 592
                  The timing marks look fine.
                  • driftin jo
                    • Sep 2007
                    • 2222
                    Sounds like it could be a broken wiring loom to me as you have short to pos and then short to earth.
                    pull the connector of the cam sensor and ECU and run a continuity test from pin to pin and from pins to earth etc.
                    http://www.s2central.net/motronic_pinout_ABY.html this will help
                    • bernsaudi
                      • Feb 2007
                      • 592
                      Time to get the meter out!
                      • bernsaudi
                        • Feb 2007
                        • 592
                        does anyone have any resistance values to check the cam sensor for?
                        • driftin jo
                          • Sep 2007
                          • 2222
                          this will be of some help, ways of testing etc
                          http://forums.quattroworld.com/s4s6/msgs/22580.phtml
                          • bernsaudi
                            • Feb 2007
                            • 592
                            Thanks for that, will have a go in a bit
                            • bernsaudi
                              • Feb 2007
                              • 592
                              Update, now shows a code that say g40 cam sensor static- mechanical malfunction...I put a scope on pin 8 and i have a cam sensor signal going to the ecu when trying to start, I checked the crank reference signal and crank speed sensor (pin 47 and 49 if memory serves) also and found what look like pertinent signals. I used pin 19 for ground in all three readings. I have approximate figures for these which I will put up later. Is there anything else which can trigger this error? for example the vehicle speed sensor error which is evident while you scan with the engine off? Any ideas? I have put 2 different cam sensors on and they work fine when tested for a reading .
