Following on from this thread :
The Colgate wagon is running rough at present, pulled the codes and cannot seem to loose 2341.
Symptoms are poor cold start, starts fine then a few seconds after goes lumpy idling as low as 500 rpm and when you hit the gas it wants to cut out, I'd say it's running rich.
Once upto running temp it's better and although still lumpy idles ~850rpm.
Driving is a little jerky when changing gear but generally ok apart from being a bit hesitant at around 1.5 bar
Code relates to this;
-Fuel tank empty at least 10 litres
-Fuel system pressure too low
-Failure of spark plugs, ignition coils
and ignition output stages
-Ingress of air to G70
-Leak in exhaust system up to catalyst
-Faulty lambda probe
-Fuel system pressure too high
Plenty of fuel,year old 044 fitted
New plugs,1.8t coil conversion, although plugs checked since and black so cleaned
No exhaust leaks(found dp leaking but now sealed)
New Bosch lambda
New temp sensor on rear of head
Had a boost leak few weeks back repaired intercooler but haven't re-tested yet. Mfts connector was unplugged as broken but replacement now fitted
I find it odd how it improves once warm.
Any thoughts ? For me I'm going for possibly fpr, lambda no good,maf,fuel filter (been meaning to change for ages ) boost leak naturally
This all started one morning when I started it after going away for a week and we started getting cold weather.
Rs2 setup on ts chips
Thanks all, constructive feedback most great fully accepted !
New Bosch lambda
