Cam belt and Head gasket change!
  • Glen Chamberlain
    • 375
    Hi all! I thought it was time to get off my **** and change the cam belt! 106k and no record of replacement? ops: But as always i cant do things simple! My RS2 turbo is on the way so with advice from Paul N the head gasket is being replace for the RS2 metal one!
    Bits on their way from Martynf are:
    Belt
    Pensioner
    Idler Pulley
    Crank Bolt
    Water pump (From Stealers)
    Head Gasket and bolts
    All drive belts too!
    Have i missed owt? (Please say no???? iam getting skint now!!)
    Also any tips from those who have done any of this before are more than welcome????
    Thanks guys! the more info the better !!!!
    Money is everything! Second to Power of course!!! But money breeds power??
  • Glen Chamberlain
    • 375
    by the way its a tensioner not a pensioner! (i hope! Martyn?)
    • Doug_RS2
      • 3847
      I can't offer any help but if you could do a step by step guide for us it would help me a lot in the future - with some pictures?
      • Glen Chamberlain
        • 375
        Ok ill try! But in return I want some lettuce and stuff along with a hutch to live in? (Guinea pigs do eat lettuce and stuff and live in hutches don't they?)
        • Doug_RS2
          • 3847
          deal
          • Chris M
            • Sep 2003
            • 1030
            I did the cambelt on my 3b engine along with all the other belts,what a joy that was.:wacked: The water pump on the 3b engine is the tensioner and having fitted the belt and adjusting it all up the water pump then started to leak so it had to come off and have a new seal fitted. Took me 8 hours start to finish,just glad its out the way now. . Can concentrate on more mods now.Have fun with yours Glen.
            Cheers,
            Chris
            Silver S2 Avant : Sold
            • martinjs
              • 3205
              Glen, id reccomend you change the thermestat too even if yours is ok, theyre only cheap and a total nightmare to get at with everything in place.
              i recently had my head off to do a head overhaul and fit rs2 turbo,
              i found it easier to undo turbo to manifold bolts and take head and manifolds off as one (you'll need an assistant to help lift as it weighs a ton)
              especially if your keeping stock exhaust manifold (are you?)
              give all your water pipes a good check over, especially water feed to turbo,
              breather pipes also, mine had turned to sludge!!
              good luck
              martin
              • audiman
                • 4827
                LOL, did my h/gasket 3 months ago i took loads of pics, too many to post!!
                Not too bad a job, just crap access. But change the stat, also check all the breather hoses cos they are a bitch to get at when back together.
                Hope you have some serious tools to get that crankshaft pulley bolt out. It darn tight!!
                HTH
                Tom C - www.rcmr.co.uk
                Audi UR Quattro
                Audi 100 C3 2.0 5 cyl 115ps
                Audi B5 RS4 645ps 911nm
                • Glen Chamberlain
                  • 375
                  1 inch drive sockets and an torque miltiplyer 4 to 1!! so yeh i have! Bolts and stuff is very tight on coach's!! Are these the bolts that can damage the end of the crank when there really really tight?
                  • audiman
                    • 4827
                    Fairplay mate
                    Dont over tighten it mind. and use a BIT of loctite when putting back together.
                    Audi UR Quattro
                    • Glen Chamberlain
                      • 375
                      Tourqes?
                      Has anyone got any spec on torque settings? I need at least the head bolts, but any more are welcome cos as a rule i generaly use torques when figures are available?
                      Thanks Guys?
                      Glen C.
                      :confused:
                      • Audi Parts Guru
                        • 1317
                        Glen,Martyn and myself are sending you an 82 year old spinster who's not seen any form of action for over 40 years
                        • audiman
                          • 4827
                          Glen I have the torques for all of the head bolts/nuts.
                          BUT its at work, im going there in a bit tho. Post them later.
                          Audi UR Quattro
                          • Glen Chamberlain
                            • 375
                            Sorry guys it'll be no use to me!! my hernia is playing up!!!!!!!!!!!!!!
                            • Glen Chamberlain
                              • 375
                              It's coming to bits niceley!
                              The bumper, rad, ic, cross member, air box/intake pipes and cam belt all came off in just over an hour, but theres no way on gods given earth that it'll all go back a quick! where poss iv'e tried to put bolts back in threads after so i know where they all go but ive loads of bits that are homeless already, and thers along way to go yet? I have take some pics but for some reason they havent arrived to my inbox yet so can't show you? (taken @ work and mailed) there looks to be days work not hours! i kinda wish i haddn't started now! (It was all such a good idea in theory too! ) Is ther only 6 allen bolts holdin the cam cover on? cos if there is, it's well stuck! Any other tips and avice available now is the time guys?
                              Ah well lets see how it looks tomorrow?
