Cam belt and Head gasket change!
  • porkkis
    • 1994
    Only 6 bolts and mine was quite tight also...
    • Doug_RS2
      • 3847
      Look at Mikes website for help with that cam cover:
      link
      Have you unscrewed those threaded pems (never heard that description before) - see Mikes pics.
      • Glen Chamberlain
        • 375
        Excellent! thanks for that Doug! i wasn't aware of them two thingies! top man!
        Money is everything! Second to Power of course!!! But money breeds power??
        • Martynf
          • 1885
          Glen,
          I kow the feeling with days of work rather than hours! felt the same when I ripped mine apart!
          If it helps you, here's a link to the RC change on mine: http://www.vagparts.com/S2/D3/rad3.htm
          Martyn
          Martyn
          www.vagparts.com
          • Glen Chamberlain
            • 375
            #20
            Originally posted by Martynf
            Glen,
            IMartyn
            'll probably use it for re-assembley cos my memory is like a? dam cant quite remember what its like now????? :confused:
            • Josh-stateside
              • 741
              Cylinder head
              Disassembling and assembling
              Note: Cylinder head can be removed and installed with engine installed.
              Removing and installing toothed belt Repair Group 13
              Removing and installing fuel injectors
              Repair Manual, 2.22 Liter 5-Cyl. Turbo Fuel Injection & Ignition, Engine Code(s): AAN
              Cylinder heads with cracks between valve seats or between valve seat and spark plug threads may be reused without reducing service life, provided cracks do not exceed 0.5 mm (0.020 in.) width, or when no more than first threads are cracked.
              When installing replacement cylinder head with camshaft installed, contact surfaces between valve lifters and cam lobe surfaces must be oiled after installing cylinder head.
              When replacing cylinder head or head gasket, replace all coolant.
              Checking compression pressures Page 15-7
              15-2
              1 - Cylinder head gasket
              Always replace
              Ensure correct installation position: "OBEN" marking or part number must face cylinder head
              Instlall gasket over centering pins in cylinder block
              2 - 20 Nm (15 ft lb)
              3 - Gasket
              Always replace
              4 - Cylinder head
              Checking for distortion Fig. 1
              Resurfacing dimensions Fig. 2
              Installing Page 15-6
              Servicing valve train Page 15-9
              5 - 65 Nm (48 ft lb)
              6 - Cylinder head bolts
              Always replace
              Follow installation instructions and sequence when loosening and tightening Page 15-6
              7 - Heat shield
              8 - 65 Nm (48 ft lb)
              15-3
              9 - 10 Nm (7 ft lb)
              Tighten diagonally
              10 - Gasket
              Flanged surface must face exhaust manifold
              11 - 25 Nm (18 ft lb)
              Always replace
              12 - Exhaust manifold
              With turbocharger
              13 - 10 Nm (7 ft lb)
              14 - Spring with bracket
              15 - 10 Nm (7 ft lb)
              16 - Cover
              With ignition coils
              17 - Gasket
              Only replace if damaged
              Insert in groove in cover
              18 - Not applicable
              19 - 10 Nm (7 ft lb)
              20 - 10 Nm (7 ft lb)
              15-4
              21 - Bracket
              For vacuum hoses
              22 - Cylinder head cover
              23 - Gasket for cylinder head cover
              Insert in groove on cylinder head cover
              24 - Plugs
              25 - Intake manifold
              Use Allen socket VAG 1669 to remove and install
              26 - Bolt
              For oil dipstick guide tube
              10 Nm (7 ft lb)
              27 - Gasket
              Always replace
              28 - O-ring
              Always replace
              29 - Coolant pipe
              30 - 10 Nm (7 ft lb)
              15-5
              Fig. 1 Checking cylinder head for distortion
              - Measure with feeler gauge at several locations.
              Distortion: max. 0.1 mm (0.004 in.)
              Fig. 2 Resurfacing cylinder head
              Resurfacing of the cylinder head (grinding flat) is permissible up to minimum dimension -a- (measured through bolt hole).
              Dimension -a- (minimum) = 118.1 mm (4.650 in.)
              15-6
              Cylinder head, installing
              Note:
              Always replace cylinder head bolts.
              There must be no oil or coolant in the blind cylinder head bolt holes in the cylinder block.
              - Before installing cylinder head, set crankshaft and camshaft in cylinder head to Top Dead Center (TDC) for cylinder 1.
              - Fit cylinder head gasket over centering pins: "OBEN" or part number must face cylinder head (watch hole pattern).
              - Install cylinder head and cylinder head bolts; tighten by hand.
              - Tighten cylinder head bolts in total of three stages - for sequence, see diagram.
              Tightening torques (engine cold):
              Stage I:
              40 Nm
              (30 ft lb)
              Stage II:
              60 Nm
              (44 ft lb)
              Stage III:
              1/2 turn (180) further with rigid spanner without stopping
              (2 x 90 is also permissible)
              Note: Loosen cylinder head bolts in reverse order.
              Additional retightening of bolts is not required.
              15-7
              Compression pressure, checking
              Engine warm-coolant temperature gauge at approx. 80C (176F).
              - Turn quick fasteners (arrows) on connector cover on rear engine compartment bulkhead 90 to left and remove cover.
              - Mark and separate connectors -5- and -6- (to ignition coils).
              - Remove cover with coils on cylinder head cover Page 15-3 .
              - Unscrew all spark plugs with spark plug wrench 3122 A.
              - Check compression pressure with compression pressure recorder VAG 1381 and adapter 1381/1.
              Throttle valve fully open
              - Operate starter until no further pressure increase is indicated by tester.
              15-8
              Compression pressures
              Specified value: 9.0-13.0 bar (131-189 psi)
              Wear limit: 7.0 bar (102 psi)
              Maximum permissiblepressure difference betweenindividualcylinders: 3.0 bar (44 psi)
              .......NExt subject:
              Fig. 11 Removing and installing vibration damper
              Tightening torque
              With spanner 2079:
              350 Nm
              (258 ft lb)
              Without spanner 2079:
              450 Nm
              (332 ft lb)
              - Use brace 3256.
              - Coat threads and contact surfaces of bolt head with sealing paste AMV 188 001 02.
              Note:
              Spanner 2079 for vibration damper must align with torque wrench.
              Email me if you need some pictures..
              Hope you can read this btw.
              Josh
              • audiman
                • 4827
                ********, dont fit a head with a crack. It will not last. You can get the head welded up. Nice one Audi, i wonder if this was written by their mechanics and not the factory!!!
                Tom C - www.rcmr.co.uk
                Audi UR Quattro
                Audi 100 C3 2.0 5 cyl 115ps
                Audi B5 RS4 645ps 911nm
                • Josh-stateside
                  • 741
                  I forgot some info:
                  Note becarefully of some of the tighening torques bently mentions.
                  Ex: they state 15ft pounds for the idle pulley on the aby/aan motors. But that's way too much. I actually broke the bolt.
                  Just use your best judgement on any bolt smaller than 8mm.
                  Josh
                  • Glen Chamberlain
                    • 375
                    #24
                    heads off!
                    Well its come off! The head is on the bench with both manifolds and turbo still attached. But how sick was i too see that it already had a metal gasket fitted!! But i suppose iam fitting peace of mind now? The head came of much easer than i expected! not nessasarily easy but easier! I'll take some piccs tomorrow @ work and post them with the others!
                    Theres not really an "how to" as such, but just unbolt the head and remove what needs to be removed! follow your nose really?
                    • Josh-stateside
                      • 741
                      That's a 3b motor btw.
                      You can tell cause the water pump can be adjusted.
                      No comment on this design from audi, but I am certainly glad they changed that.
                      • Mark Halligan
                        • 2001
                        Nice info Josh, going to be doing this soon.
                        Thanks,
                        Mark.
                        Mark - Modded
                        • desmo888
                          • Oct 2003
                          • 390
                          Use some vaseline in the o-ring for the waterpump. This will allow the o-ring to slide easily during adjustment and let it seal well.
                          Don't let this project itimidate you! You're doing fine. Just take your time and enjoy it. Don't get too anxious, get the timing belt slack just right.
                          I'll be rebuilding a 3B soon so any tips would be appreciated.
                          You may want to check my timing belt change instructions on www.20v.org
                          I've done a few.
                          Dave K.
                          '90 CQ - soon to be turbo powered...
                          Dave K.
                          USA
                          1991 e//S2 (home built S2 - the only way to get one in USA!)
                          2001 S4
                          • Josh-stateside
                            • 741
                            That's another person's motor btw.
                            Also on the Es2 list: Ben from canada.
                            My motor has alllready made it's way into the engine bay
                            • desmo888
                              • Oct 2003
                              • 390
                              That Klumper Hoser, I know him. He's been a huge help in getting me started.
                              Dave K.
                              USA
                              2001 S4
                              • porkkis
                                • 1994
                                Mine has a crack and I'm going to put it back. It was pressure tested and no visual signs of any leaks were found.
