My s6 for some unknown reason is not starting as it should. I don't think its the hall sender, as I have had this problem before and replaced it. This is different. It starts after a few turns, but wont run unless I feather the throttle. when driving I can feel the engine is not running as well as it should all the time. What ever the problem is its very intermittent. The car runs ok 90% of the time.
I intend to check it out latter today if I can. I replaced the fuel pump a few weeks ago with a new unit I wonder if this has anything to do with it. The car ran fine after I fitted it, with no issues.
Any help as always would be much appreciated.
The 00515 code. Camshaft position sender 20-10 malfunction in basic settings-intermittent.
