no oil pressure after engine rebuilt
  • ACQ
    • Jun 2008
    • 141
    • Country: Lithuania
    I have rebuilt 3b engine with 7a head. At first start engine ran without any scary noises, but no oil pressure in the block (in oil pressure sender place) - 0bar (mechanic gauge also)! Oil pressure is good in the turbo inlet. What could be the problem?
    Oil thermostat open a bore only to the oil radiator? could it close a bore to the block if it was installed wrong? I don't know what is wrong and I really won't to disassemble an engine again..
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    your oil check valve is stuck or damaged! look here post 19.
    Goodluck!
    • ACQ
      • Jun 2008
      • 141
      Thanks. I hope that it is the problem
      • ACQ
        • Jun 2008
        • 141
        Could I start the engine without this oil check valve? . Main was demaged
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          Yes, you can.
          But check iff the engine is ok than replace as you will loose oil from the head during startup.
          Hope the engine is ok.
          Regards!
          • ACQ
            • Jun 2008
            • 141
            I hope so. i will try to start engine without this valveand look at pressure
            • Pirvu Eugen
              • Apr 2007
              • 1978
              • Country: Romania
              Goodluck!
              Post result please!
              • ACQ
                • Jun 2008
                • 141
                4.5bar on cold. I think it is too low...
                • Pirvu Eugen
                  • Apr 2007
                  • 1978
                  • Country: Romania
                  Is ok...maibe the oil pressure relief valve is set a little low. no rattles?
                  No noises? Check with engine warm.
                  • AndyP
                    • 6049
                    Sounds a little low for a cold start, what oil are you using?
                    That valve must have an affect on oil pressure, I'd get a new one ASAP
                    • piotr
                      • Jul 2012
                      • 1470
                      i would expect to see good 5 BAR on cold start
                      • AndyP
                        • 6049
                        The gauge should be maxed, I'm sure it goes to around 6bar cold.
                        • ACQ
                          • Jun 2008
                          • 141
                          I use stack mechanic gauge. I won't warp up it long because I am not connected water. I just keep 1.30min engine running and it sounds without any noises and oil pressure showed 4bar at 1000rpm in the and. It is really low I think. Does the oil pressure valve increase a pressure?
                          • AndyP
                            • 6049
                            I don't know for certain, but I'm pretty sure it will
                            • Pirvu Eugen
                              • Apr 2007
                              • 1978
                              • Country: Romania
                              The pressure sensors are after the valve into the head path. I am pretty sure that the valve will not increase the oil pressure reading from those 2 sensors.
                              I think you should fit the water radiators and run the engine till normal running temps and check then.
                              What oil you use?
