I carried out a boost leak test the other day to try and resolve my excessive lag issue, it highlighted air leaking past 2 of the injectors - 4 & 5 (I assume these are the only 2 on which the inlet valves were open so more might be leaking).
I have purchased new seals but they are still leaking, using a tire pump I can get the pressure in the intake up to about 10psi, when I switch it off the pressure drops to zero in 40 seconds. I had blocked the breather system for the test.
The seals I bought are the larger 15mm OD, I had the option of 14.5 or 15 so bought the biggest.
Im now thinking it could be the inserts but cant imagine they could wear out as they are a stiff material and it isn't as if there are moving parts to cause wear, so unless heat cycling or age can cause distortion??? has anyone else has this issue.
