Just looking at this pipe arrangement earlier, the GT3071 compressor outlet feeds the original 3B Samco which joins to an adapter into the Wagner IC. It does look a bit restricted. Just wondering if I should put the adapter at the turbo end and feed the IC with 3" tube. (or whatever the Wagner size is) ?
Air flows through the centre and will not touch the sides, this will cause turbulence but as as is a forced flow should not really have issues further than appearance
