Urs4 coils??
  • GazzaG60
    • 4133
    check the boots on the end of the coils too. especially if you just had the plugs done. they may have gone more damage.
      One missing and hesitation diagnostic
      Originally posted by mike74
      Something that might show a defective coil is the old fashioned way of testing spark at plugs.
      True. I have recommended a spark gap test for OE coils but never for the coilpacks.
      One missing and hestitation diagnostic:
      • igor136
        • Jun 2014
        • 363
        • Country: Croatia
        #33
        Today bought a new coil. I do not know if there's anything better. Maybe a little. I have a little longer to drive a car. It is interesting that with the OEM coils car works great. I have a question, grounding for internal POS I took from the pin number 2 of the first and second four pin connector, together. So, as shown only one additional wire. Is that same?
        1-2-4-5-3
          As the diagram indicates, there are two grounds for the coilpacks. One is from Pin 2/4 of the coilpacks, back to the ECU at Pin 2 of the 4 pin Harness connector. The second coilpack ground goes from Pin 4/4 on the coil packs to somewhere on the head, e.g. the right rear bolt on the cam cover (using a large ring terminal).
          • igor136
            • Jun 2014
            • 363
            • Country: Croatia
            #35
            I use this system, with one wire more
            1-2-4-5-3
            • igor136
              • Jun 2014
              • 363
              • Country: Croatia
              #36
              I tried a new coil, same ****. I found something interesting. The coil is dependent on the voltage. I think I have a bad voltage regulator.
              Battery Voltage-dependent closing and charging time
              8V => 3,3ms
              10V=> 3,0ms
              12V => 2,6ms
              14V => 2,4ms
              16V => 1,5ms
              1-2-4-5-3
              • ade-5
                • Apr 2014
                • 76
                Thanks for the advice guys. Nearly positive it's the coils! Just waiting for someone on the forum to get back to me with when he can get the new loom 2 me ☺
