Anybody have an idea what this turbine is off
Turbine wheel
Large diameter 64mm
Small diameter 54mm
Wheel width 24mm
Flat section across the top of the wheel is 10mm wide
When fitted to a K26 Turbine housing and then to the rest of an RS2 what performance do you think it would produce compared to a standard RS2 turbo.
Should I just hold out to get the right hot side housing. (original RS2)
orsum
Turbine wheel
Large diameter 64mm
Small diameter 54mm
Wheel width 24mm
orsum
