Turbine size
  • orsum
    • May 2010
    • 1213
    • Home: United Kingdom Current: South Africa
    Turbine size
    Anybody have an idea what this turbine is off
    Turbine wheel
    Large diameter 64mm
    Small diameter 54mm
    Wheel width 24mm
    Flat section across the top of the wheel is 10mm wide
    When fitted to a K26 Turbine housing and then to the rest of an RS2 what performance do you think it would produce compared to a standard RS2 turbo.
    Should I just hold out to get the right hot side housing. (original RS2)
    orsum
  • Quattronaut
    • May 2013
    • 273
    Seems to be normal K26. Exducer is 64,4mm, inducer is 54,1mm. Don“t know the 2 other measures, but this turbine wheel is very wide spread, so very probably it is.
    Fit to RS2 comp side will give a turbo with similiar peak power to normal RS2 turbo, but more lag.
    • orsum
      • May 2010
      • 1213
      Thanks Quattronaut
      Do you think it would be better to use an RS2 Turbine housing? I have the turbine wheel. I am having a problem finding a replacement RS2 housing.
      Any idea how much lag?
      orsum
      • Quattronaut
        • May 2013
        • 273
        I would prefer the stock RS2 hotside. It is good for 400hp and more, and gives a pretty quick throttle response.I don“t really know how much more lag it is, cause it depends on the rest of the setup, but I estimate boost to be around 200-300rpm later. And spool-up, the throttle response itself is slower.
        To be honest- I dont really like that K26 wheel. Because the RS2 K24 K2 is better. So for me, there is no reason for the K26 K1, unles you will go for more than 420hp, and use the 8"hotside housing. But everyone uses those K26 with the 6housing...don“t know why. But if you can“t find a RS2 housing, you don“t have much choice ;-)
        • orsum
          • May 2010
          • 1213
          Once again thanks,
          Borg warner South Africa are trying to get me a housing I hope they can.
          Anybody have a housing for sale or know were I can get an RS2 Turbine housing?
          orsum
          • Quattronaut
            • May 2013
            • 273
            Why do you need RS2 housing, do you have a RS2 turbine wheel?
            • orsum
              • May 2010
              • 1213
              Yes I have the RS2 turbine wheel.
              orsum
              • Quattronaut
                • May 2013
                • 273
                Why are all you guys collecting turbine wheels and then looking for housings in here?? ;-)
                • orsum
                  • May 2010
                  • 1213
                  Used as a paper weight
                  Sorry should not have asked for help finding one in this section my apologies.
                  orsum
                  • orsum
                    • May 2010
                    • 1213
                    Just for interest sake this is the reply from
                    richard@turboexchange.co.za
                    The Borg Warner supplier in South Africa.
                    UNFORTUNATELY THE FACTORY DOES NOT SUPPLY THE HOUSING LOOSE
                    THE ONLY ALTERNATIVE IS TO GET A PRICE ON THE COMPLTE TURBO
                    orsum
