How to diagnose a boost leak?
  • Jack4688
    • May 2010
    • 1004
    I'm officially waiting to hear if my new car has been written off before delving into and remedial action on the S2 but my mind does tend to drift and think about these things...
    I've definitely got boost but there's no longer that kick you get at about 2500-3000 rpm, is that indicative of a boost leak somewhere? What steps can I take to identify it?
    ABY Boost Leak Testing
    Yes. The first step would have been to search the forum archives, "Any Date" and "boost leak testing". That should have found you this (and others):
    • Rikki Kitto
      • Feb 2010
      • 6276
      You need to give it to someone who can do a boost leak test or get the kit and do it yourself, I chased boost leaks for 18 months trying to avoid using the test kitDo the test, you will be shocked where leaks can occur. Behind jubilee clips is a good one to try find without the test kit
      • Jack4688
        • May 2010
        • 1004
        Thanks fellas, it's gone on the back burner again as I had to abandon the S2 at work today - as you said David in your thread 'things that will fail on your AAN/ABY/ADU' (I can't remember the exact name) when your cam position sensor is dying you are on borrowed time and I think I've used all mine up!
          G40 Cam Sensor Replacement DIY pdfs
          Both originally done on a google/picasa website by Nate P (ImQuattro). Captured and converted to pdfs in the event of (another) picasa failure:
          Small version (300 kB):
          Large version (3.2 Mb):
          • Jack4688
            • May 2010
            • 1004
            Thanks David, that'll be bookmarked ready for job #1 when my restoration starts!
